(mmdet_env) andolab@andolab:~/mmdet_env$ trtexec --onnx=/home/andolab/mmdet_env/model.onnx --saveEngine=/home/andolab/mmdet_env/model.trt --fp16
&&&& RUNNING TensorRT.trtexec [TensorRT v100300] # trtexec --onnx=/home/andolab/mmdet_env/model.onnx --saveEngine=/home/andolab/mmdet_env/model.trt --fp16
[01/27/2025-00:11:28] [I] === Model Options ===
[01/27/2025-00:11:28] [I] Format: ONNX
[01/27/2025-00:11:28] [I] Model: /home/andolab/mmdet_env/model.onnx
[01/27/2025-00:11:28] [I] Output:
[01/27/2025-00:11:28] [I] === Build Options ===
[01/27/2025-00:11:28] [I] Memory Pools: workspace: default, dlaSRAM: default, dlaLocalDRAM: default, dlaGlobalDRAM: default, tacticSharedMem: default
[01/27/2025-00:11:28] [I] avgTiming: 8
[01/27/2025-00:11:28] [I] Precision: FP32+FP16
[01/27/2025-00:11:28] [I] LayerPrecisions:
[01/27/2025-00:11:28] [I] Layer Device Types:
[01/27/2025-00:11:28] [I] Calibration:
[01/27/2025-00:11:28] [I] Refit: Disabled
[01/27/2025-00:11:28] [I] Strip weights: Disabled
[01/27/2025-00:11:28] [I] Version Compatible: Disabled
[01/27/2025-00:11:28] [I] ONNX Plugin InstanceNorm: Disabled
[01/27/2025-00:11:28] [I] TensorRT runtime: full
[01/27/2025-00:11:28] [I] Lean DLL Path:
[01/27/2025-00:11:28] [I] Tempfile Controls: { in_memory: allow, temporary: allow }
[01/27/2025-00:11:28] [I] Exclude Lean Runtime: Disabled
[01/27/2025-00:11:28] [I] Sparsity: Disabled
[01/27/2025-00:11:28] [I] Safe mode: Disabled
[01/27/2025-00:11:28] [I] Build DLA standalone loadable: Disabled
[01/27/2025-00:11:28] [I] Allow GPU fallback for DLA: Disabled
[01/27/2025-00:11:28] [I] DirectIO mode: Disabled
[01/27/2025-00:11:28] [I] Restricted mode: Disabled
[01/27/2025-00:11:28] [I] Skip inference: Disabled
[01/27/2025-00:11:28] [I] Save engine: /home/andolab/mmdet_env/model.trt
[01/27/2025-00:11:28] [I] Load engine:
[01/27/2025-00:11:28] [I] Profiling verbosity: 0
[01/27/2025-00:11:28] [I] Tactic sources: Using default tactic sources
[01/27/2025-00:11:28] [I] timingCacheMode: local
[01/27/2025-00:11:28] [I] timingCacheFile:
[01/27/2025-00:11:28] [I] Enable Compilation Cache: Enabled
[01/27/2025-00:11:28] [I] errorOnTimingCacheMiss: Disabled
[01/27/2025-00:11:28] [I] Preview Features: Use default preview flags.
[01/27/2025-00:11:28] [I] MaxAuxStreams: -1
[01/27/2025-00:11:28] [I] BuilderOptimizationLevel: -1
[01/27/2025-00:11:28] [I] Calibration Profile Index: 0
[01/27/2025-00:11:28] [I] Weight Streaming: Disabled
[01/27/2025-00:11:28] [I] Runtime Platform: Same As Build
[01/27/2025-00:11:28] [I] Debug Tensors:
[01/27/2025-00:11:28] [I] Input(s)s format: fp32:CHW
[01/27/2025-00:11:28] [I] Output(s)s format: fp32:CHW
[01/27/2025-00:11:28] [I] Input build shapes: model
[01/27/2025-00:11:28] [I] Input calibration shapes: model
[01/27/2025-00:11:28] [I] === System Options ===
[01/27/2025-00:11:28] [I] Device: 0
[01/27/2025-00:11:28] [I] DLACore:
[01/27/2025-00:11:28] [I] Plugins:
[01/27/2025-00:11:28] [I] setPluginsToSerialize:
[01/27/2025-00:11:28] [I] dynamicPlugins:
[01/27/2025-00:11:28] [I] ignoreParsedPluginLibs: 0
[01/27/2025-00:11:28] [I] === Inference Options ===
[01/27/2025-00:11:28] [I] Batch: Explicit
[01/27/2025-00:11:28] [I] Input inference shapes: model
[01/27/2025-00:11:28] [I] Iterations: 10
[01/27/2025-00:11:28] [I] Duration: 3s (+ 200ms warm up)
[01/27/2025-00:11:28] [I] Sleep time: 0ms
[01/27/2025-00:11:28] [I] Idle time: 0ms
[01/27/2025-00:11:28] [I] Inference Streams: 1
[01/27/2025-00:11:28] [I] ExposeDMA: Disabled
[01/27/2025-00:11:28] [I] Data transfers: Enabled
[01/27/2025-00:11:28] [I] Spin-wait: Disabled
[01/27/2025-00:11:28] [I] Multithreading: Disabled
[01/27/2025-00:11:28] [I] CUDA Graph: Disabled
[01/27/2025-00:11:28] [I] Separate profiling: Disabled
[01/27/2025-00:11:28] [I] Time Deserialize: Disabled
[01/27/2025-00:11:28] [I] Time Refit: Disabled
[01/27/2025-00:11:28] [I] NVTX verbosity: 0
[01/27/2025-00:11:28] [I] Persistent Cache Ratio: 0
[01/27/2025-00:11:28] [I] Optimization Profile Index: 0
[01/27/2025-00:11:28] [I] Weight Streaming Budget: 100.000000%
[01/27/2025-00:11:28] [I] Inputs:
[01/27/2025-00:11:28] [I] Debug Tensor Save Destinations:
[01/27/2025-00:11:28] [I] === Reporting Options ===
[01/27/2025-00:11:28] [I] Verbose: Disabled
[01/27/2025-00:11:28] [I] Averages: 10 inferences
[01/27/2025-00:11:28] [I] Percentiles: 90,95,99
[01/27/2025-00:11:28] [I] Dump refittable layers:Disabled
[01/27/2025-00:11:28] [I] Dump output: Disabled
[01/27/2025-00:11:28] [I] Profile: Disabled
[01/27/2025-00:11:28] [I] Export timing to JSON file:
[01/27/2025-00:11:28] [I] Export output to JSON file:
[01/27/2025-00:11:28] [I] Export profile to JSON file:
[01/27/2025-00:11:28] [I] === Device Information ===
[01/27/2025-00:11:28] [I] Available Devices:
[01/27/2025-00:11:28] [I] Device 0: “Orin” UUID: GPU-efa7eec7-56ef-5dc0-9ee6-8cbd3607653f
[01/27/2025-00:11:28] [I] Selected Device: Orin
[01/27/2025-00:11:28] [I] Selected Device ID: 0
[01/27/2025-00:11:28] [I] Selected Device UUID: GPU-efa7eec7-56ef-5dc0-9ee6-8cbd3607653f
[01/27/2025-00:11:28] [I] Compute Capability: 8.7
[01/27/2025-00:11:28] [I] SMs: 4
[01/27/2025-00:11:28] [I] Device Global Memory: 15655 MiB
[01/27/2025-00:11:28] [I] Shared Memory per SM: 164 KiB
[01/27/2025-00:11:28] [I] Memory Bus Width: 256 bits (ECC disabled)
[01/27/2025-00:11:28] [I] Application Compute Clock Rate: 0.918 GHz
[01/27/2025-00:11:28] [I] Application Memory Clock Rate: 0.612 GHz
[01/27/2025-00:11:28] [I] Note: The application clock rates do not reflect the actual clock rates that the GPU is currently running at.
[01/27/2025-00:11:28] [I] TensorRT version: 10.3.0
[01/27/2025-00:11:28] [I] Loading standard plugins
[01/27/2025-00:11:28] [I] [TRT] [MemUsageChange] Init CUDA: CPU +2, GPU +0, now: CPU 31, GPU 5506 (MiB)
[01/27/2025-00:11:32] [I] [TRT] [MemUsageChange] Init builder kernel library: CPU +928, GPU +751, now: CPU 1002, GPU 6302 (MiB)
[01/27/2025-00:11:32] [I] Start parsing network model.
[01/27/2025-00:11:32] [I] [TRT] ----------------------------------------------------------------
[01/27/2025-00:11:32] [I] [TRT] Input filename: /home/andolab/mmdet_env/model.onnx
[01/27/2025-00:11:32] [I] [TRT] ONNX IR version: 0.0.6
[01/27/2025-00:11:32] [I] [TRT] Opset version: 11
[01/27/2025-00:11:32] [I] [TRT] Producer name: pytorch
[01/27/2025-00:11:32] [I] [TRT] Producer version: 2.3.0
[01/27/2025-00:11:32] [I] [TRT] Domain:
[01/27/2025-00:11:32] [I] [TRT] Model version: 0
[01/27/2025-00:11:32] [I] [TRT] Doc string:
[01/27/2025-00:11:32] [I] [TRT] No checker registered for op: GatherTopk. Attempting to check as plugin.
[01/27/2025-00:11:32] [E] [TRT] IPluginRegistry::getCreator: Error Code 4: API Usage Error (Cannot find plugin: GatherTopk, version: 1, namespace:.)
[01/27/2025-00:11:32] [I] [TRT] No checker registered for op: TRTBatchedNMS. Attempting to check as plugin.
[01/27/2025-00:11:32] [E] [TRT] IPluginRegistry::getCreator: Error Code 4: API Usage Error (Cannot find plugin: TRTBatchedNMS, version: 1, namespace:.)
[01/27/2025-00:11:32] [I] [TRT] No checker registered for op: MMCVMultiLevelRoiAlign. Attempting to check as plugin.
[01/27/2025-00:11:32] [E] [TRT] IPluginRegistry::getCreator: Error Code 4: API Usage Error (Cannot find plugin: MMCVMultiLevelRoiAlign, version: 1, namespace:.)
[01/27/2025-00:11:32] [E] [TRT] ModelImporter.cpp:948: While parsing node number 545 [GatherTopk → “/GatherTopk_output_0”]:
[01/27/2025-00:11:32] [E] [TRT] ModelImporter.cpp:950: — Begin node —
input: “/Concat_21_output_0”
input: “/TopK_output_1”
output: “/GatherTopk_output_0”
op_type: “GatherTopk”
domain: “mmdeploy”
[01/27/2025-00:11:32] [E] [TRT] ModelImporter.cpp:951: — End node —
[01/27/2025-00:11:32] [E] [TRT] ModelImporter.cpp:953: ERROR: onnxOpCheckers.cpp:780 In function checkFallbackPluginImporter:
[6] creator && “Plugin not found, are the plugin name, version, and namespace correct?”
[01/27/2025-00:11:32] [E] [TRT] ModelImporter.cpp:948: While parsing node number 554 [GatherTopk → “/GatherTopk_1_output_0”]:
input: “/Concat_19_output_0”
output: “/GatherTopk_1_output_0”
domain: “mmdeploy”
[01/27/2025-00:11:32] [E] [TRT] ModelImporter.cpp:948: While parsing node number 610 [GatherTopk → “/GatherTopk_2_output_0”]:
input: “/Concat_30_output_0”
input: “/TopK_1_output_1”
output: “/GatherTopk_2_output_0”
domain: “mmdeploy”
[01/27/2025-00:11:32] [E] [TRT] ModelImporter.cpp:948: While parsing node number 619 [GatherTopk → “/GatherTopk_3_output_0”]:
input: “/Concat_28_output_0”
output: “/GatherTopk_3_output_0”
domain: “mmdeploy”
[01/27/2025-00:11:32] [E] [TRT] ModelImporter.cpp:948: While parsing node number 673 [GatherTopk → “/GatherTopk_4_output_0”]:
input: “/Concat_39_output_0”
input: “/TopK_2_output_1”
output: “/GatherTopk_4_output_0”
domain: “mmdeploy”
[01/27/2025-00:11:32] [E] [TRT] ModelImporter.cpp:948: While parsing node number 682 [GatherTopk → “/GatherTopk_5_output_0”]:
input: “/Concat_37_output_0”
output: “/GatherTopk_5_output_0”
domain: “mmdeploy”
[01/27/2025-00:11:32] [E] [TRT] ModelImporter.cpp:948: While parsing node number 736 [GatherTopk → “/GatherTopk_6_output_0”]:
input: “/Concat_48_output_0”
input: “/TopK_3_output_1”
output: “/GatherTopk_6_output_0”
domain: “mmdeploy”
[01/27/2025-00:11:32] [E] [TRT] ModelImporter.cpp:948: While parsing node number 745 [GatherTopk → “/GatherTopk_7_output_0”]:
input: “/Concat_46_output_0”
output: “/GatherTopk_7_output_0”
domain: “mmdeploy”
[01/27/2025-00:11:32] [E] [TRT] ModelImporter.cpp:948: While parsing node number 799 [GatherTopk → “/GatherTopk_8_output_0”]:
input: “/Concat_57_output_0”
input: “/TopK_4_output_1”
output: “/GatherTopk_8_output_0”
domain: “mmdeploy”
[01/27/2025-00:11:32] [E] [TRT] ModelImporter.cpp:948: While parsing node number 808 [GatherTopk → “/GatherTopk_9_output_0”]:
input: “/Concat_55_output_0”
output: “/GatherTopk_9_output_0”
domain: “mmdeploy”
[01/27/2025-00:11:32] [E] [TRT] ModelImporter.cpp:948: While parsing node number 891 [TRTBatchedNMS → “/TRTBatchedNMS_output_0”]:
input: “/Unsqueeze_95_output_0”
input: “/Concat_64_output_0”
output: “/TRTBatchedNMS_output_0”
output: “/TRTBatchedNMS_output_1”
op_type: “TRTBatchedNMS”
attribute {
i: -1
type: INT
attribute {
i: 0
type: INT
attribute {
f: 0.7
type: FLOAT
attribute {
i: 0
type: INT
attribute {
i: 1000
type: INT
attribute {
i: 1
type: INT
attribute {
i: 0
type: INT
attribute {
f: 0.05
type: FLOAT
attribute {
i: 5000
type: INT
domain: “mmdeploy”
[01/27/2025-00:11:32] [E] [TRT] ModelImporter.cpp:948: While parsing node number 928 [MMCVMultiLevelRoiAlign → “/bbox_roi_extractor/MMCVMultiLevelRoiAlign_output_0”]:
input: “/Reshape_50_output_0”
input: “/neck/fpn_convs.0/conv/Conv_output_0”
input: “/neck/fpn_convs.1/conv/Conv_output_0”
input: “/neck/fpn_convs.2/conv/Conv_output_0”
input: “/neck/fpn_convs.3/conv/Conv_output_0”
output: “/bbox_roi_extractor/MMCVMultiLevelRoiAlign_output_0”
op_type: “MMCVMultiLevelRoiAlign”
attribute {
i: 1
type: INT
attribute {
floats: 4
floats: 8
floats: 16
floats: 32
type: FLOATS
attribute {
i: 56
type: INT
attribute {
i: 7
type: INT
attribute {
i: 7
type: INT
attribute {
i: 1
type: INT
attribute {
f: 1
type: FLOAT
attribute {
i: 0
type: INT
domain: “mmdeploy”
[01/27/2025-00:11:32] [E] [TRT] ModelImporter.cpp:948: While parsing node number 1030 [TRTBatchedNMS → “/TRTBatchedNMS_1_output_0”]:
input: “/Unsqueeze_116_output_0”
input: “/Slice_14_output_0”
output: “/TRTBatchedNMS_1_output_0”
output: “/TRTBatchedNMS_1_output_1”
attribute {
i: -1
type: INT
attribute {
i: 0
type: INT
attribute {
f: 0.5
type: FLOAT
attribute {
i: 0
type: INT
attribute {
i: 100
type: INT
attribute {
i: 6
type: INT
attribute {
i: 0
type: INT
attribute {
f: 0.05
type: FLOAT
attribute {
i: 5000
type: INT
domain: “mmdeploy”
[01/27/2025-00:11:32] [E] [TRT] ModelImporter.cpp:948: While parsing node number 1064 [MMCVMultiLevelRoiAlign → “/mask_roi_extractor/MMCVMultiLevelRoiAlign_output_0”]:
input: “/Reshape_61_output_0”
output: “/mask_roi_extractor/MMCVMultiLevelRoiAlign_output_0”
attribute {
i: 1
type: INT
attribute {
floats: 4
floats: 8
floats: 16
floats: 32
type: FLOATS
attribute {
i: 56
type: INT
attribute {
i: 14
type: INT
attribute {
i: 14
type: INT
attribute {
i: 1
type: INT
attribute {
f: 1
type: FLOAT
attribute {
i: 0
type: INT
domain: “mmdeploy”
[01/27/2025-00:11:32] [E] Failed to parse onnx file
[01/27/2025-00:11:32] [I] Finished parsing network model. Parse time: 0.434691
[01/27/2025-00:11:32] [E] Parsing model failed
[01/27/2025-00:11:32] [E] Failed to create engine from model or file.
[01/27/2025-00:11:32] [E] Engine set up failed
&&&& FAILED TensorRT.trtexec [TensorRT v100300] # trtexec --onnx=/home/andolab/mmdet_env/model.onnx --saveEngine=/home/andolab/mmdet_env/model.trt --fp16
When I try to convert to the TensorRT engine, I get this error. However, I can build the TensorRT plugin from Git and set it in the environment variables. Is this a problem specific to MMDetection? Or is it a flaw in the TensorRT plugin?
(mmdet_env) andolab@andolab:~/mmdet_env$ ls /usr/lib/aarch64-linux-gnu | grep libnvinfer_plugin
libnvinfer_plugin.so
libnvinfer_plugin.so.10
libnvinfer_plugin.so.10.3.0
libnvinfer_plugin_static.a
(mmdet_env) andolab@andolab:~/mmdet_env$ echo $LD_LIBRARY_PATH
/usr/local/cuda-12.6/lib64::/usr/lib/aarch64-linux-gnu
