When trying this url “wirple_dot_com/bmark/” (replace dot with an actual dot, as a new user I am limited to 1 url link in my post), fps are around 50-80fps and other javascript 3d libs examples (Threejs…), I have the same performance using my i915 or my rtx2060.
To use the rtx, I launch firefox with primusrun /path/to/firefox I should have a fps increase. My laptop (Asus ROG) has a 144Hz screen. it should not be capped much below for such a simple scene, especially with the RTX. primusrun glxgears -info shows nvidia card is used.
I also have some screen glitches at times, very fast and random as it seems.
HDMI screen doesn’t work under Linux, but works fine under Windows. That is a real problem for me, because most of the time, the laptop is for development work.
Any attempt to upgrade the linux kernel to, say 5.16 or 5.18 with matching kernel header via backports leads to install errors (dkms related). But that point is non essential for me, if the two above can be solved.
Please note,the kernel module and everything is installed and no errors are thrown (with the kernel 5.10). No xorg config file is created either.
On a 3D website under Windows, the gtx 2060 runs at 144fps (max Hz of my screen) while on Linux 50fps (even with the option __NV_PRIME_RENDER_OFFLOAD=1 __GLX_VENDOR_LIBRARY_NAME=nvidia firefox). Which means the RTX 2060 doesn’t kick in.
Any help? Kernel 5.10 seems my only option as of now, 5.18 rejects driver 470.
I tried the 515 driver from Nvidia, no luck either.
And still no HDMI while it works out of the box on Windows. That point is really annoying.
Still the same errors on module loading and the nvidia-drm module is missing completely. This won’t work. Why can’t you access anything else than driver 460? Again, how did you install the driver?
Just tried the backports:
Purge beforehand, reinstall the linux-headers, reboot.
Now, I run 470. The system made me update modprobe, but still no luck with nvidia-settings.
