Hi, I’m having problems when I run the sample deepstream-app in Deepstream 5.0. I am using the docker container with the tag deepstream:5.0-dp-20.04-devel on a remote server with this setup:
deepstream-app version 5.0.0
DeepStreamSDK 5.0.0
CUDA Driver Version: 10.2
CUDA Runtime Version: 10.2
TensorRT Version: 7.0
cuDNN Version: 7.6
libNVWarp360 Version: 2.0.1d3
These are the errors:
root@6652db923a9d:/pkl2/deepstream-5.0/sources/apps/sample_apps/deepstream-app# ./deepstream-app -c …/…/…/…/samples/configs/deepstream-app/config_infer_primary.txt
** ERROR: main:651: Failed to set pipeline to PAUSED
Quitting
ERROR from src_bin_muxer: Output width not set
Debug info: gstnvstreammux.c(2125): gst_nvstreammux_change_state (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstNvStreamMux:src_bin_muxer
App run failed
root@6652db923a9d:/opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-app# ./deepstream-app -c …/…/…/…/samples/configs/deepstream-app/source30_1080p_dec_infer-resnet_tiled_display_int8.txt
Quitting
App run failed
I have not changed source30_1080p_dec_infer-resnet_tiled_display_int8.txt but I have added the following onto the end of config_infer_primary.txt for a file output
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=3
uri=file:///opt/nvidia/deepstream/deepstrewm-5.0/samples/streams/sample_1080p_h264.mp4
num-sources=1
#drop-frame-interval=2
gpu-id=0
cudadec-memtype=0[sink0]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming 5=Overlay
type=2
sync=0
display-id=0
offset-x=0
offset-y=0
width=0
height=0
overlay-id=1
source-id=0[sink2]
enable=1
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265 3=mpeg4
codec=3
sync=1
bitrate=2000000
output-file=out.mp4
source-id=0[tests]
file-loop=0
