Setup:
Ubuntu 18.04
| NVIDIA-SMI 390.116 Driver Version: 390.116 |
| 0 GeForce GTX 675M Off | 00000000:01:00.0 N/A | N/A |
| 0% 64C P1 N/A / N/A | 582MiB / 1977MiB | N/A Default |
| 1 GeForce GTX 675M Off | 00000000:07:00.0 N/A | N/A |
| 0% 56C P12 N/A / N/A | 56MiB / 1985MiB | N/A Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 Not Supported |
| 1 Not Supported |
Installed:
sudo sh ./cuda_9.1.85_387.26_linux.run --verbose --silent --toolkit --override
sudo sh ./cuda_9.1.85.1_linux.run --silent --accept-eula
sudo sh ./cuda_9.1.85.2_linux.run --silent --accept-eula
sudo sh ./cuda_9.1.85.3_linux.run --silent --accept-eula
gcc --version
gcc (Ubuntu 6.5.0-2ubuntu1~18.04) 6.5.0 20181026
cd ~/Projects/cuda-testing/samples/
make -j4
All samples build without error but none run actually run with errors like :
cd bin/x86_64/linux/release
./simpleSurfaceWrite
simpleSurfaceWrite starting…
MapSMtoCores for SM 2.1 is undefined. Default to use 64 Cores/SM
GPU Device 0: “GeForce GTX 675M” with compute capability 2.1
CUDA device [GeForce GTX 675M] has 8 Multi-Processors, SM 2.1
Loaded ‘lena_bw.pgm’, 512 x 512 pixels
CUDA error at simpleSurfaceWrite.cu:227 code=37(cudaErrorInvalidSurface) “cudaBindSurfaceToArray(outputSurface, cuArray)”
I have seen a number of other posts in this forum regarding these errors which all suggest my setup is still not correct.
Any ideas appreciated.
