I’m trying to change the example code “sampleUffMaskRCNN” to inference from an OpenCV input image (cv::mat) instead of a PPM file.
The code runs but it doesn’t return any detection if the input image is from a cv::mat. If i get the image from a PPM file it works well.
My processInput function is this (based on Custom trained SSD inception model in tensorRT c++ version - #14 by AastaLLL):
bool MaskRCNN::processInput(const samplesCommon::BufferManager& buffers)
try
const int inputC = mInputDims.d[0];
const int inputH = mInputDims.d[1];
const int inputW = mInputDims.d[2];
const int batchSize = MaskRCNNConfig::BATCH_SIZE;
cv::Mat origin_image = cv::imread(MaskRCNNConfig::IMAGE_TEST);
if (!origin_image.data)
std::cout << "Error : could not load image." << std::endl;
return false;
cv::Mat resize_image;
cv::resize(origin_image, resize_image, cv::Size(inputH, inputW), cv::INTER_CUBIC);
// Fill data buffer
float* hostDataBuffer = static_cast<float*>(buffers.getHostBuffer(MaskRCNNConfig::MODEL_INPUT));
for (int i = 0, volImg = inputH * inputW; i < batchSize; ++i)
for (unsigned j = 0, volChl = inputH * inputW; j < inputH; ++j)
for (unsigned k = 0; k < inputW; ++ k)
cv::Vec3b bgr = resize_image.at<cv::Vec3b>(j,k);
hostDataBuffer[i * volImg + 0 * volChl + j * inputW + k] = (2.0 / 255.0) * float(bgr[2]) - 1.0;
hostDataBuffer[i * volImg + 1 * volChl + j * inputW + k] = (2.0 / 255.0) * float(bgr[1]) - 1.0;
hostDataBuffer[i * volImg + 2 * volChl + j * inputW + k] = (2.0 / 255.0) * float(bgr[0]) - 1.0;
return true;
catch (std::exception& e)
//Exit Function
return false;
Thanks,
Luis Silva
