Scene Importer Issue
I followed the guideline in Scene Importer — Aerial Omniverse Digital Twin to generate the example file tokyo_small:
root@e24d4182a693:/src/aodt_gis/aodt_py/aodt_ui_gis# python3 gis_jobs/gml_job.py -i /src/aodt_gis/data/13100_tokyo23-ku_2022_citygml_1_2_op/udx/bldg/53393599_bldg_6697_2_op.gml -ei 6697 -eo 32654 -o /src/aodt_gis/data/tokyo_small.usd
in_gmls /src/aodt_gis/data/13100_tokyo23-ku_2022_citygml_1_2_op/udx/bldg/53393599_bldg_6697_2_op.gml
epsg_in 6697
epsg_out 32654
/src/aodt_gis/build/aodt_gis  /src/aodt_gis/data/13100_tokyo23-ku_2022_citygml_1_2_op/udx/bldg/53393599_bldg_6697_2_op.gml -o /src/aodt_gis/data/tmp.usd --epsg_in 6697 --epsg_out 32654 -v info
running command: /src/aodt_gis/build/aodt_gis  /src/aodt_gis/data/13100_tokyo23-ku_2022_citygml_1_2_op/udx/bldg/53393599_bldg_6697_2_op.gml -o /src/aodt_gis/data/tmp.usd --epsg_in 6697 --epsg_out 32654 -v info
Warning: in _ReportErrors at line 3168 of /usr/src/OpenUSD/pxr/usd/usd/stage.cpp -- In </Materials/standard>: Could not open asset @/src/aodt_gis/assets/materials.usda@ for reference introduced by @/src/aodt_gis/data/tmp.usd@</Materials/standard>. (instantiating stage on stage @/src/aodt_gis/data/tmp.usd@ <0x55eb6021c850>)
Warning: in _ReportErrors at line 3168 of /usr/src/OpenUSD/pxr/usd/usd/stage.cpp -- In </Environment/sky>: Could not open asset @https:/omniverse-content-production.s3.us-west-2.amazonaws.com/Assets/Skies/2022_1/Skies/Dynamic/ClearSky.usd@ for reference introduced by @/src/aodt_gis/data/tmp.usd@</Environment/sky>. (instantiating stage on stage @/src/aodt_gis/data/tmp.usd@ <0x55eb6021c850>)
proj_create: unrecognized format / unknown name
setting default materials...
Warning: in _ReportErrors at line 3157 of /buildAgent/work/aed3087ace93e092/USD/pxr/usd/usd/stage.cpp -- In </Materials/standard>: Could not open asset @/src/aodt_gis/assets/materials.usda@ for reference introduced by @/src/aodt_gis/data/tmp.usd@</Materials/standard>. (instantiating stage on stage @/src/aodt_gis/data/tmp.usd@ <0x55822cec4ac0>)
copying textures directory...
updating texture references...
output stage: /src/aodt_gis/data/tokyo_small.usd, textures name : tokyo_small_textures
Warning: in _ReportErrors at line 3157 of /buildAgent/work/aed3087ace93e092/USD/pxr/usd/usd/stage.cpp -- In </Materials/standard>: Could not open asset @/src/aodt_gis/assets/materials.usda@ for reference introduced by @/src/aodt_gis/data/tokyo_small.usd@</Materials/standard>. (instantiating stage on stage @/src/aodt_gis/data/tokyo_small.usd@ <0x55822d766c20>)
Execution time: 26 seconds.
When I opened the USD file in AODT, it showed only a small ground plane with no buildings visible. In the right panel I can see many building meshes but clicking on them does not highlight anything in the viewport.
Solved. Used EPSG:6697 and EPSG:32654 for ei and eo parameters.
