Hello, I bought a jetson nano with 16 gb emmc from WAYPONDEV .
I installed the jetpack 4.6.3 using sdkmanager and then tried to flash it . I followed the correct steps then I used “sudo ./flash.sh jetson-nano-emmc mmcblk0p1” to flash the jetson. Everything was fine but the sd card is not recognized : there is no /dev/mmcblk1p1 only there is /dev/mmcblk0* so I couldn’t finish the process and boot it from sd card
When I use the command “dmegs --follow” nothing happens when I plug or unplug the sd card !
Please I need this to be solved asap,!
