SD card support for Jetson Orin NX
Hello. We are evaluating the use of Jetson Orin NX together with the Boson carrier board from Connect Tech for use on a drone. However, we need to support logging of large amounts of camera and 3D data to an SD card.
I was told by Connect Tech that Jetson Orin NX does not have the required SDIO signals to support an SD card.
How would you recommend we go about to add support for an SD card on this platform? Do you have any suggested products that would add SD card support via e.g. PCIe, USB or any other available interface? We need as high performance I/O as possible, as we are logging large amounts of data in real time.
I recommend you to refer to this link.
https://www.genesyslogic.com.tw/product_list.php?1st=1&2nd=7
Orin NX does not support SD card directly. Maybe you can check with custom board vendor for this.
