SDI 3G Camera Capture on Jetson AGX Orin – Is DeckLink Duo 2 Mini a Good Option?
I’m starting a vision project using a Jetson AGX Orin and plan to connect a camera via SDI 3G. I’m considering the DeckLink Duo 2 Mini for video capture.
Is this card a good choice for use with Jetson Orin? Any compatibility issues I should be aware of? If not recommended, are there better alternatives?
Antonio
Thank you for considering the Jetson AGX Orin for your vision project. I’d be happy to help you with your question.
The DeckLink Duo 2 Mini is a popular video capture card, but its compatibility with the Jetson AGX Orin is not explicitly stated. However, I can provide some insights to help you make an informed decision.
SDI 3G Support: The Jetson AGX Orin supports SDI 3G, which is a good starting point. However, it’s essential to verify that the DeckLink Duo 2 Mini can capture SDI 3G signals and transmit them to the Jetson AGX Orin via a compatible interface (e.g., PCIe).
PCIe Compatibility: The DeckLink Duo 2 Mini is a PCIe card, and the Jetson AGX Orin has PCIe slots. However, you should ensure that the card is compatible with the Jetson AGX Orin’s PCIe version and lane configuration. The Jetson AGX Orin supports PCIe Gen4, while the DeckLink Duo 2 Mini supports up to PCIe Gen3. This might not be a significant issue, but it’s crucial to verify that the card can operate at a lower PCIe version if necessary.
Driver Support: To use the DeckLink Duo 2 Mini with the Jetson AGX Orin, you’ll need to ensure that there are compatible drivers available for the card. Blackmagic Design, the manufacturer of the DeckLink Duo 2 Mini, provides drivers for various operating systems, including Linux. However, you should verify that the drivers are compatible with the Jetson AGX Orin’s Linux distribution (e.g., L4T) and version.
Alternative Options: If you’re concerned about compatibility issues or want to explore alternative options, here are a few:
  1. NVIDIA’s own SDI capture cards: NVIDIA offers SDI capture cards specifically designed for their Jetson platforms, such as the NVIDIA SDI Capture Card. These cards are optimized for use with Jetson modules and might offer better compatibility and performance.
  2. Other third-party SDI capture cards: There are other third-party SDI capture cards available that might be compatible with the Jetson AGX Orin. Some popular options include cards from AJA, Bluefish444, and Magewell. Be sure to research each option’s compatibility and performance with the Jetson AGX Orin.
Recommendation: While the DeckLink Duo 2 Mini might work with the Jetson AGX Orin, I recommend exercising caution and verifying compatibility before making a purchase. If you’re unsure about compatibility or want a more straightforward solution, consider NVIDIA’s own SDI capture cards or other third-party options that have been tested with the Jetson AGX Orin.
I hope this information helps you make an informed decision for your vision project, Antonio. If you have any further questions or concerns, feel free to ask!
