I’m trying to flash a Jetson Orin AGX Developer Kit with JetPack version 5.0.2. According to the SDK, it successfully flashes the OS and installs the Jetson SDK components. When it gets to the end of the process, I get an error on the SDK Manager that says:
“BSP Version Mismatch Your device BSP image version is incompatible with the softawre version you are trying to install. Please reflash your device with the right BSP version and try to reinstall.”
However, when in the SDK Manager itself, under target components, it says that it successfully installed everything. Why would this error show up when the SDK Manager is saying that it installed all of the target components?
