I will add some trivia which you might be interested in…
In recovery mode a Jetson is a custom USB device, and needs a custom driver (a Jetson cannot self-flash because it does not have a BIOS, thus custom USB device instead). The “driver package” is appropriately named because it is what understands that custom USB device, and it runs on the host PC (most of what you find in “Linux_for_Tegra/
” is the driver package). The “sample root filesystem” is what actually gets flashed. In the past there was no GUI, no JetPack, and no SDK Manager. One would download the driver package, unpack the sample rootfs into the “Linux_for_Tegra/rootfs/
” directory (which is purely Ubuntu), and then overlay the NVDIA content onto the “rootfs/
” (which is when it becomes “Linux for Tegra” instead of just “Ubuntu”) using the apply_binaries.sh
script. All flashing on command line worked after that.
One of the limitations was that installing many of the optional software items (such as CUDA) was a separate step. This is when host PC had to be a specific release since it was also installing optional tools on the host PC and not just optional content on the Jetson, e.g., it also can install the NVIDIA video driver and CUDA development tools on the host PC, not just the Jetson. It might have been better to not have that requirement, but to simply gray out/neutralize the checkboxes for installing host PC items.
However, the “Linux_for_Tegra/
” content is itself not changed by much over the years. The command line tools, e.g., flash.sh
, still deal only with flash, and not with options, and so these do not have any particular host PC requirement other than being Linux desktop PC.
Note that you can still find the “driver package” and “sample root filesystem” on any given L4T release page. You don’t actually need JetPack/SDK Manager to install this. So if you were to find your L4T release version here:
https://developer.nvidia.com/linux-tegra
Then you could download and unpack the driver package anywhere as a regular user. You’d then download and unpack the sample rootfs in the resulting empty “Linux_for_Tegra/rootfs/
”, and finally, add NVIDIA drivers with the “Linux_for_Tegra/
” directories command “sudo ./apply_binaries.sh
”. After that you could run the command line flash, and it should work even from other distributions, e.g., Fedora. You’d have to know what to install though in terms of options like CUDA, which would be a more manual operation.
Interestingly enough, you could update a newly installed Jetson, clone it, and put that in to replace “Linux_for_Tegra/rootfs/
” content. Flash might alter extlinux.conf
, user accounts, the device tree, or kernel, but the rest would be a verbatim copy of what is in “rootfs/
