Hello, I need to install SDK MANAGER in order to install JETPACK but cannot connect. The message appears once the software is opened: session expired please log in again
Do you have any idea to fix this?
thank you very much
thank you very much
Which Jetosn device you’re work with?
Are you using a native Ubuntu host PC with SDK manager? Which Ubuntu OS version?
You can also first install the L4T OS:
https://docs.nvidia.com/jetson/archives/r35.4.1/DeveloperGuide/text/IN/QuickStart.html
Then install JetPack SDK on the device with:
sudo apt update
sudo apt install nvidia-jetpack
