Hello.
I recently changed my GPU to a 1080 Ti and I have a problem since, which causes that my second monitor not showing any signal when I launch Windows 11.
That second monitor is an AOC 75 hz 2560 x 1440 and only shows image when launching W11 if previously I configured its refresh rate to 60 hz. If I configure 75 hz, the only way to show image is if I extract de HDMI and putting it again (and just in SOME tries, when I ALT+P and select ‘‘extend’’ or ‘‘duplicate’’).
I tried much ways to solve this problem and nothing works (using CRU, reinstalling NVIDIA drivers, monitor drivers, Windows Update is up to date…). I have the HDMI connected to one splitter, but I tried connecting it directly to the monitor which does not work.
With my previous GPU (RX 5700) I had 0 problems, both monitors were detected instantly at W11 launch and I were capable to turn signal from one to another without issues (with the same HDMI), so the problem might be with the 1080 or Nvidia drivers.
For more information, my main monitor is an AOC UW (344X1440) 144 hz connected via Display port.
What else can I do? Any suggestions are appreciated.
