That would require me to somehow install the older drivers on Arch to test them out, as I just got the video card less than a week ago. Should I try out the latest 570 branch? Or test out some older versions of the 580 branch?
I’d be willing to try molding the Arch nvidia-utils PKGBUILD to bundle up different branches or older versions, if you think I should try checking them for the same behavior.
Edit: Still having the sync issues after DPMS on 580.95.05, including a diagnostic log from that after the problem started occurring, will try the next older driver in a moment.
nvidia-bug-report.log.gz (2.0 MB)
Edit: Still doing it on 580.82.09, another diagnostic log:
nvidia-bug-report.log.gz (2.1 MB)
Edit: And again on 580.76.05, so another log:
nvidia-bug-report.log.gz (1.8 MB)
Incidentally, I think this is a separate issue from the flickering, which seems to have gone away with the -4 pkgrel of 580.105.08 on Arch. That one was probably the displayport bug others experienced.
Edit: First version where it did not start losing sync on my second monitor: 575.64.05. Diagnostic logs provided from this version:
Edit: 570.207 has the bug:
Edit: 570.195.03 has the bug:
Edit: And again with 570.190:
Edit: Again on 570.181:
nvidia-bug-report.log.gz (1.6 MB)
Edit: Again on 570.172.08:
Edit: And gone again when I reached 570.169:
Adding basic reproducer attempt for the bug that happens:
- Log into KDE 6.5.3 Wayland, possibly with an HDR display, but at least one not. All displays on DP, VRR set to Automatic.
- Wait for dust to settle on login apps.
- Apps should include Chromium, Chrome, or Microsoft Edge.
- Open a tab to these forums, on the main page.
- Navigate into the Linux 580 megathread.
- Lock the displays with Super+L.
- Press ESC so the displays immediately enter sleep mode.
- Wait for all monitors to time out from any “entering power save mode” notices and actually go to sleep.
- Press a key to wake the displays.
- Unlock the desktop.
- Repeatedly navigate the forums tab between the main index and the topic.
- Observe as misbehaving monitor (LG) loses sync regularly when the browser navigation happens.
8/9, if you do not have a monitor that detaches itself from the bus on power on or wake like my LG monitor does, then try hotplugging a monitor at this step. This may be necessary to reproduce the conditions.
