Hello all,
As my previous posts have mentioned, I’m working on a custom image for the Jetson Nano (dev kit currently). Once this image is complete, I’d like to implement secure boot. Referring to the following wiki post on the meta-tegra layer used to design the image, I’ve seen a note that the developer kit is not compatible with secure boot: https://github.com/OE4T/meta-tegra/wiki/Secure-Boot-Support
- NVIDIA does not support secure boot on SDcard-based developer kits (Jetson Nano/Nano-2GB and Jetson Xavier NX). You may render your developer kit permanently unbootable if you attempt to burn the secure boot fuses .
Is this statement true? In that secure-boot is not supported when using the Jetson Nano Developer Kit?
Thanks,
Brenden
