Segfault on Removing the Last Stream From the Pipeline
• Hardware Platform (Jetson / GPU): GPU
• DeepStream Version: 6.4
• JetPack Version (valid for Jetson only): -
• TensorRT Version: 8.6.1.6-1+cuda12.0
• NVIDIA GPU Driver Version (valid for GPU only): 535.183.01
• Issue Type (questions, new requirements, bugs): questions, bugs
• How to reproduce the issue? (This is for bugs. Including which sample app is used, the configuration files content, the command line used, and other details for reproducing): runtime_source_add_delete and deepstream_test_4
• Requirement details (This is for the new requirement. Including the module name which plugin or for which sample application, and the function description): uridecodebin → nvstreammux → nvinfer → nvtracker → nvinfer → nvinfer → nvvideoconvert → capsfilter → nvmsgconv → nvmsgbroker
I have a pipeline implemented in Python by combining the Deepstream samples runtime_source_add_delete and deepstream_test_4. It adds multiple sources to the pipeline, then attaches metadata to each buffer using a probe function defined on the source pad of the Capsfilter, and finally publishes event messages through Redis using Nvmsgconv and Nvmsgbroker elements. You can find the code below:
# ruff: noqa: E402
# fmt: off
import sys
import gi  # type: ignore
gi.require_version("Gst", "1.0")
from gi.repository import GLib, Gst  # type: ignore
sys.path.append("../")
Gst.init(None)
# fmt: on
import configparser
import logging
import time
from enum import IntEnum
from threading import Thread
import cv2  # type: ignore
import numpy as np  # type: ignore
import pyds  # type: ignore
from common.platform_info import PlatformInfo  # type: ignore
from common.utils import long_to_uint64  # type: ignore
from numpy.typing import NDArray  # type: ignore
GPU_ID = 0
MAX_NUM_SOURCES = 4
UNTRACKED_OBJECT_ID = -1
MAX_TIMESTAMP_LENGTH = 32
STREAM_MUXER_RESOLUTION = (1920, 1080)
STREAM_MUXER_BATCH_SIZE = 30
STREAM_MUXER_BATCHED_PUSH_TIMEOUT = 25000
PRIMARY_INFERENCE_CONFIG_FILE = "dstest_pgie_config.txt"
TRACKER_CONFIG_FILE = "dstest_tracker_config.txt"
SECONDARY_INFERENCE_1_CONFIG_FILE = "dstest_sgie1_config.txt"
SECONDARY_INFERENCE_2_CONFIG_FILE = "dstest_sgie2_config.txt"
MESSAGE_CONVERTER_CONFIG_FILE = "dstest4_msgconv_config.txt"
MESSAGE_CONVERTER_SCHEMA_TYPE = 0
MESSAGE_BROKER_PROTO_LIB = (
    "/opt/nvidia/deepstream/deepstream/lib/libnvds_redis_proto.so"
MESSAGE_BROKER_CONFIG = "/opt/nvidia/deepstream/deepstream/sources/libs/redis_protocol_adaptor/cfg_redis.txt"
MESSAGE_BROKER_CONN_STR = "redis;6379;test"
MESSAGE_BROKER_TOPIC = "test"
g_num_sources = 0
g_source_id_list = [-1] * MAX_NUM_SOURCES
g_eos_list = [False] * MAX_NUM_SOURCES
g_source_enabled = [False] * MAX_NUM_SOURCES
g_source_bin_list = [None] * MAX_NUM_SOURCES
g_uri = "file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.mp4"
platform_info = None
loop = None
pipeline = None
stream_muxer = None
logging.basicConfig(level=logging.DEBUG)
logger = logging.getLogger(__name__)
class ClassID(IntEnum):
    VEHICLE = 0
    BICYCLE = 1
    PERSON = 2
    ROADSIGN = 3
def generate_vehicle_meta() -> pyds.NvDsVehicleObject:
    obj = pyds.alloc_nvds_vehicle_object()
    obj = pyds.NvDsVehicleObject.cast(obj)
    obj.type = "sedan"
    obj.color = "blue"
    obj.make = "Bugatti"
    obj.model = "M"
    obj.license = "XX1234"
    obj.region = "CA"
    return obj
def generate_person_meta() -> pyds.NvDsPersonObject:
    obj = pyds.alloc_nvds_person_object()
    obj = pyds.NvDsPersonObject.cast(obj)
    obj.age = 45
    obj.cap = "none"
    obj.hair = "black"
    obj.gender = "male"
    obj.apparel = "formal"
    return obj
def get_frame_array(gst_buffer: Gst.Buffer, batch_id: int) -> NDArray:
    frame_array = pyds.get_nvds_buf_surface(hash(gst_buffer), batch_id)
    frame_array = np.ascontiguousarray(frame_array)
    frame_array = np.frombuffer(frame_array, dtype=np.uint8)
    width, height = STREAM_MUXER_RESOLUTION
    frame_array = frame_array.reshape(height, width, 3)
    frame_array = cv2.cvtColor(frame_array, cv2.COLOR_BGR2RGB)
    return frame_array
def generate_event_metadata(
    source_id: int,
    frame_id: int,
    user_meta: pyds.NvDsUserMeta,
    object_meta: pyds.NvDsObjectMeta,
) -> pyds.NvDsEventMsgMeta:
    metadata = pyds.alloc_nvds_event_msg_meta(user_meta)
    metadata = pyds.NvDsEventMsgMeta.cast(metadata)
    metadata.sensorId = 0
    metadata.placeId = 0
    metadata.moduleId = 0
    metadata.sensorStr = "sensor-0"
    metadata.ts = pyds.alloc_buffer(MAX_TIMESTAMP_LENGTH + 1)
    pyds.generate_ts_rfc3339(metadata.ts, MAX_TIMESTAMP_LENGTH)
    metadata.bbox.top = object_meta.rect_params.top
    metadata.bbox.left = object_meta.rect_params.left
    metadata.bbox.width = object_meta.rect_params.width
    metadata.bbox.height = object_meta.rect_params.height
    metadata.frameId = frame_id
    metadata.trackingId = long_to_uint64(object_meta.object_id)
    metadata.confidence = object_meta.confidence
    match object_meta.class_id:
        case ClassID.VEHICLE:
            metadata.type = pyds.NvDsEventType.NVDS_EVENT_MOVING
            metadata.objType = pyds.NvDsObjectType.NVDS_OBJECT_TYPE_VEHICLE
            metadata.objClassId = ClassID.VEHICLE
            metadata.extMsg = generate_vehicle_meta()
            metadata.extMsgSize = sys.getsizeof(pyds.NvDsVehicleObject)
        case ClassID.PERSON:
            metadata.type = pyds.NvDsEventType.NVDS_EVENT_ENTRY
            metadata.objType = pyds.NvDsObjectType.NVDS_OBJECT_TYPE_PERSON
            metadata.objClassId = ClassID.PERSON
            metadata.extMsg = generate_person_meta()
            metadata.extMsgSize = sys.getsizeof(pyds.NvDsPersonObject)
    return metadata
def attach_metadata(
    frame_meta: pyds.NvDsFrameMeta,
    frame_array: NDArray,
    source_id: int,
) -> None:
    event_metadata = generate_event_metadata(
        source_id=source_id,
        frame_id=frame_meta.frame_num,
        user_meta=user_meta,
        object_meta=object_meta,
    user_meta.base_meta.meta_type = pyds.NvDsMetaType.NVDS_EVENT_MSG_META
    user_meta.user_meta_data = event_metadata
    pyds.nvds_add_user_meta_to_frame(frame_meta, user_meta)
def iterate_object_meta_list(
    batch_meta: pyds.NvDsBatchMeta,
    source_id: int,
) -> None:
    l_obj = frame_meta.obj_meta_list
    while l_obj is not None:
        try:
            object_meta = pyds.NvDsObjectMeta.cast(l_obj.data)
            tracking_id = long_to_uint64(object_meta.object_id)
            if tracking_id == UNTRACKED_OBJECT_ID:
                logger.debug("No tracking ID found for object")
                raise ValueError
            user_meta = pyds.nvds_acquire_user_meta_from_pool(batch_meta)
            if user_meta:
                attach_metadata(
                    frame_meta, user_meta, object_meta, frame_array, source_id
            else:
                logger.error("Failed to acquire user meta")
        except StopIteration:
            logger.debug("Iterating object meta list is over")
        except ValueError:
            logger.debug("Skipping an invalid object meta")
        finally:
            try:
                l_obj = l_obj.next
                break
def extract_metadata(pad: Gst.Pad, info: Gst.PadProbeInfo) -> Gst.PadProbeReturn:
    global g_source_id_list
    gst_buffer = info.get_buffer()
    if not gst_buffer:
        logger.warning("Unable to get buffer from pad")
        return Gst.PadProbeReturn.DROP
    batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
    if not batch_meta:
        return Gst.PadProbeReturn.OK
    l_frame = batch_meta.frame_meta_list
    while l_frame is not None:
        try:
            if frame_meta.pad_index not in g_source_id_list:
                logger.warning(f"No source found for pad index {frame_meta.pad_index}")
                raise StopIteration
            source_id = g_source_id_list[frame_meta.pad_index]
            logger.debug(
                f"Extracting metadata for stream '{source_id}' at frame {frame_meta.frame_num}"
            frame_array = get_frame_array(gst_buffer, frame_meta.batch_id)
            iterate_object_meta_list(batch_meta, frame_meta, frame_array, source_id)
            logger.debug("Iterating frame metadata list is over")
        finally:
            try:
                l_frame = l_frame.next
                break
def source_bin_child_added(
    child_proxy: Gst.ChildProxy,
    emitter_object: Gst.Object,
    element_name: str,
    source_id: int,
) -> None:
    global platform_info
    logger.debug(f"Element '{element_name}' added for source '{source_id}'")
    # decodebin
    if element_name.startswith("decodebin"):
        emitter_object.connect("child-added", source_bin_child_added, source_id)
    # nvv4l2decoder
    elif element_name.startswith("nvv4l2decoder"):
        if platform_info.is_integrated_gpu():  # type: ignore
            emitter_object.set_property("enable-max-performance", True)
            emitter_object.set_property("drop-frame-interval", 0)
            emitter_object.set_property("num-extra-surfaces", 0)
        else:
            emitter_object.set_property("gpu_id", GPU_ID)
    # source
    elif element_name.startswith("source"):
        source_element = child_proxy.get_by_name(element_name)
        if source_element.find_property("drop-on-latency") is not None:
            emitter_object.set_property("drop-on-latency", True)
        # rtspsrc
        if source_element.get_factory().get_name() == "rtspsrc":
            emitter_object.set_property("protocols", "tcp")
            emitter_object.set_property("tcp-timeout", 5000000)
            emitter_object.set_property("buffer-mode", "buffer")
def source_bin_pad_added(
    source_bin: Gst.Element,
    source_pad: Gst.Pad,
    source_id: int,
) -> None:
    global stream_muxer
    source_caps: Gst.Caps = source_pad.get_current_caps()
    source_name: str = source_caps.get_structure(0).get_name()
    if not source_name.startswith("video"):
        logger.debug(f"Skipped adding non-video pad [{source_name}]")
        return
    sink_name = f"sink_{source_id}"
    sink_pad = stream_muxer.request_pad_simple(sink_name)  # type: ignore
    if not sink_pad:
        raise ValueError("Unable to create sink pad")
    result = source_pad.link(sink_pad)
    if result != Gst.PadLinkReturn.OK:
        raise ValueError(f"Failed to link pad to stream muxer for stream '{source_id}'")
    logger.debug(f"Added new '{sink_name}' pad for stream '{source_id}'")
def remove_source(source_id: int) -> bool:
    global g_num_sources
    global g_source_bin_list
    global stream_muxer
    global pipeline
    logger.info(f"Removing source '{source_id}'")
    source_bin = g_source_bin_list[source_id]
    result = source_bin.set_state(Gst.State.NULL)  # type: ignore
    if result == Gst.StateChangeReturn.FAILURE:
        logger.error(f"Failed to set source state to NULL for stream '{source_id}'")
        return False
    sink_pad = stream_muxer.get_static_pad(sink_name)  # type: ignore
    if sink_pad is None:
        logger.error(f"Sink pad '{sink_name}' for source '{source_id}' not found")
        return False
    sink_pad.send_event(Gst.Event.new_flush_stop(False))
    stream_muxer.release_request_pad(sink_pad)  # type: ignore
    pipeline.remove(source_bin)  # type: ignore
    g_source_enabled[source_id] = False
    g_source_id_list[source_id] = -1
    g_source_bin_list[source_id] = None
    g_num_sources -= 1
    return True
def add_source(source_id: int) -> bool:
    global g_source_enabled
    global g_uri
    global pipeline
    logger.info(f"Adding source '{source_id}'")
    logger.debug(f"Creating source bin for stream '{source_id}' [{g_uri}]")
    source_bin = Gst.ElementFactory.make("uridecodebin", f"source-{source_id}")
    if source_bin is None:
        raise ValueError(
            f"Unable to create source bin for stream '{source_id}' [{g_uri}]"
    source_bin.set_property("uri", g_uri)
    source_bin.connect("pad-added", source_bin_pad_added, source_id)
    source_bin.connect("child-added", source_bin_child_added, source_id)
    pipeline.add(source_bin)  # type: ignore
    result = source_bin.set_state(Gst.State.PLAYING)
        logger.error(f"Failed to set source state to PLAYING for stream '{source_id}'")
        return False
    g_source_enabled[source_id] = True
    g_source_id_list[source_id] = source_id
    g_source_bin_list[source_id] = source_bin
    g_num_sources += 1
    return True
def run() -> None:
    global loop
    global pipeline
    pipeline.set_state(Gst.State.PAUSED)  # type: ignore
    pipeline.set_state(Gst.State.PLAYING)  # type: ignore
    try:
        loop.run()  # type: ignore
    except Exception:
        print("Error happend while processing pipeline")
    pipeline.set_state(Gst.State.NULL)  # type: ignore
def start() -> Thread:
    thread = Thread(target=run, daemon=True)
    thread.start()
    return thread
def stop() -> None:
    global loop
    loop.quit()  # type: ignore
def handle_message(bus: Gst.Bus, message: Gst.Message) -> bool:
    global g_eos_list
    global loop
    logger.debug("Handle received message")
    match message.type:
        case Gst.MessageType.EOS:
            logger.info("Pipeline recieved EOS! Stopping pipeline...")
            stop()
        case Gst.MessageType.WARNING:
            warning, debug = message.parse_warning()
            logger.warning(f"Pipeline Warning: {warning}")
            logger.debug(f"Pipeline Warning Debug: {debug}")
        case Gst.MessageType.ERROR:
            error, debug = message.parse_error()
            logger.error(f"Pipeline Error: {error}")
            logger.debug(f"Pipeline Error Debug: {debug}")
            logger.info("Pipeline recieved an error! Stopping pipeline...")
            stop()
        case Gst.MessageType.ELEMENT:
            struct = message.get_structure()
            if struct is not None and struct.has_name("stream-eos"):
                parsed, stream_id = struct.get_uint("stream-id")
                if parsed:
                    logger.info(f"Received EOS for stream {stream_id}")
                    g_eos_list[stream_id] = True
                    remove_source(stream_id)
    return True
def create_pipeline():
    global loop
    global pipeline
    global stream_muxer
    loop = GLib.MainLoop()
    platform_info = PlatformInfo()
    pipeline = Gst.Pipeline()
    if not pipeline:
        raise ValueError("Unable to create Pipeline")
    bus = pipeline.get_bus()
    bus.add_signal_watch()
    bus.connect("message", handle_message)
    logger.debug("Creating stream muxer")
    stream_muxer = Gst.ElementFactory.make("nvstreammux", "stream-muxer")
    if stream_muxer is None:
        raise ValueError("Unable to create stream muxer")
    stream_muxer.set_property("gpu_id", GPU_ID)
    stream_muxer.set_property("batch-size", STREAM_MUXER_BATCH_SIZE)
    stream_muxer.set_property("batched-push-timeout", STREAM_MUXER_BATCHED_PUSH_TIMEOUT)
    stream_muxer.set_property("live-source", 1)
    stream_muxer.set_property("width", width)
    stream_muxer.set_property("height", height)
    stream_muxer.set_property("nvbuf-memory-type", int(pyds.NVBUF_MEM_CUDA_UNIFIED))
    logger.debug("Creating primary inference")
    primary_inference = Gst.ElementFactory.make("nvinfer", "primary-inference")
    if primary_inference is None:
        raise ValueError("Unable to create primary inference")
    primary_inference.set_property("config-file-path", PRIMARY_INFERENCE_CONFIG_FILE)
    primary_inference.set_property("gpu_id", GPU_ID)
    batch_size = primary_inference.get_property("batch-size")
    if batch_size < MAX_NUM_SOURCES:
        logger.warning(
            f"Overriding infer-config batch-size {batch_size} with number of sources {MAX_NUM_SOURCES}"
    primary_inference.set_property("batch-size", MAX_NUM_SOURCES)
    logger.debug("Creating tracker")
    tracker = Gst.ElementFactory.make("nvtracker", "tracker")
    if tracker is None:
        raise ValueError("Unable to create tracker")
    config = configparser.ConfigParser()
    config.read(TRACKER_CONFIG_FILE)
    config.sections()
    for key in config["tracker"]:
        if key == "tracker-width":
            tracker_width = config.getint("tracker", key)
            tracker.set_property("tracker-width", tracker_width)
        if key == "tracker-height":
            tracker_height = config.getint("tracker", key)
            tracker.set_property("tracker-height", tracker_height)
        if key == "gpu-id":
            tracker_gpu_id = config.getint("tracker", key)
            tracker.set_property("gpu_id", tracker_gpu_id)
        if key == "ll-lib-file":
            tracker_ll_lib_file = config.get("tracker", key)
            tracker.set_property("ll-lib-file", tracker_ll_lib_file)
        if key == "ll-config-file":
            tracker_ll_config_file = config.get("tracker", key)
            tracker.set_property("ll-config-file", tracker_ll_config_file)
        if key == "enable-batch-process":
            tracker_enable_batch_process = config.getint("tracker", key)
            tracker.set_property("enable_batch_process", tracker_enable_batch_process)
    logger.debug("Creating secondary inference 1")
    secondary_inference_1 = Gst.ElementFactory.make(
        "nvinfer", "secondary1-nvinference-engine"
    if secondary_inference_1 is None:
        raise ValueError("Unable to create secondary inference 1")
    secondary_inference_1.set_property("gpu_id", GPU_ID)
        "config-file-path", SECONDARY_INFERENCE_1_CONFIG_FILE
    logger.debug("Creating secondary inference 2")
    secondary_inference_2 = Gst.ElementFactory.make(
        "nvinfer", "secondary2-nvinference-engine"
    if secondary_inference_2 is None:
    secondary_inference_2.set_property("gpu_id", GPU_ID)
        "config-file-path", SECONDARY_INFERENCE_2_CONFIG_FILE
    logger.debug("Creating video converter")
    video_converter = Gst.ElementFactory.make("nvvideoconvert", "video-convertor")
    if video_converter is None:
        raise ValueError("Unable to create video converter")
    video_converter.set_property("gpu_id", GPU_ID)
    video_converter.set_property("nvbuf-memory-type", int(pyds.NVBUF_MEM_CUDA_UNIFIED))
    logger.debug("Creating filter")
    filter = Gst.ElementFactory.make("capsfilter", "filter")
    if filter is None:
        raise ValueError("Unable to create filter")
    filter_caps = Gst.Caps.from_string("video/x-raw(memory:NVMM), format=RGB")
    filter.set_property("caps", filter_caps)
    src_pad = filter.get_static_pad("src")
    if src_pad is None:
        raise ValueError("Unable to get src pad of filter")
    src_pad.add_probe(Gst.PadProbeType.BUFFER, extract_metadata)
    logger.debug("Creating message converter")
    message_converter = Gst.ElementFactory.make("nvmsgconv", "message-converter")
    if message_converter is None:
        raise ValueError("Unable to create message converter")
    message_converter.set_property("config", MESSAGE_CONVERTER_CONFIG_FILE)
    message_converter.set_property("payload-type", MESSAGE_CONVERTER_SCHEMA_TYPE)
    message_converter.set_property("msg2p-newapi", False)
    logger.debug("Creating message broker")
    message_broker = Gst.ElementFactory.make("nvmsgbroker", "message-broker")
    if message_broker is None:
        raise ValueError("Unable to create message broker")
    message_broker.set_property("sync", False)
    message_broker.set_property("proto-lib", MESSAGE_BROKER_PROTO_LIB)
    message_broker.set_property("conn-str", MESSAGE_BROKER_CONN_STR)
    message_broker.set_property("topic", MESSAGE_BROKER_TOPIC)
    if MESSAGE_BROKER_CONFIG:
        message_broker.set_property("config", MESSAGE_BROKER_CONFIG)
    logger.info("Adding elements to Pipeline")
    pipeline.add(stream_muxer)
    pipeline.add(primary_inference)
    pipeline.add(tracker)
    pipeline.add(secondary_inference_1)
    pipeline.add(secondary_inference_2)
    pipeline.add(video_converter)
    pipeline.add(filter)
    pipeline.add(message_converter)
    pipeline.add(message_broker)
    logger.info("Linking elements in the Pipeline")
    stream_muxer.link(primary_inference)
    primary_inference.link(tracker)
    tracker.link(secondary_inference_1)
    secondary_inference_1.link(secondary_inference_2)
    secondary_inference_2.link(video_converter)
    video_converter.link(filter)
    filter.link(message_converter)
    message_converter.link(message_broker)
if __name__ == "__main__":
    create_pipeline()
    thread = start()
    time.sleep(120)
    for source_id in range(4):
        add_source(source_id)
        time.sleep(10)
        remove_source(source_id)
        time.sleep(5)
    stop()
    while thread.is_alive():
        time.sleep(1)
In this sample, I add 4 streams to the pipeline and then remove them one by one. However, when the last source-bin is removed from the pipeline by calling pipeline.remove(source_bin), I receive a segfault as follows:
WARNING:__main__:Pipeline Warning: gst-resource-error-quark: No Sources found at the input of muxer. Waiting for sources. (3)
DEBUG:__main__:Pipeline Warning Debug: gstnvstreammux.cpp(2825): gst_nvstreammux_src_push_loop (): /GstPipeline:pipeline0/GstNvStreamMux:stream-muxer
Furthermore, according to the core dump, it seems the Nvvideoconvert is problematic. Here is the parsed core dump of my script:
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/usr/lib/x86_64-linux-gnu/libthread_db.so.1".
--Type <RET> for more, q to quit, c to continue without paging--
Core was generated by `python3 sample.py'.
Program terminated with signal SIGSEGV, Segmentation fault.
#0  0x00007f725c7569e5 in ?? () from /usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideoconvert.so
[Current thread is 1 (Thread 0x7f71edfff640 (LWP 783))]
Any suggestions or guidance would be greatly appreciated!
Let’s narrow down the problem first. Will there still be a crash issue if you use fakesink, like filter.link(fakesink)?
Per your suggestion, I replaced the Nvmsgconv and Nvmsgbroker elements with a Fakesink, but the pipeline crashed again after removing the last source for the same reason.
Furthermore, I was suspicious about the probe function defined on the source pad of the Capsfilter for extracting the metadata. So, I tried removing that function but it didn’t help.
Here is the core dump after this try:
#0  0x00007f4cb86bc9e5 in ?? () from /usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideoconvert.so
[Current thread is 1 (Thread 0x7f4c45fff640 (LWP 1494))]
Also, I tried something else. I changed the format of the Capsfilter to NV12 and the segfault didn’t happen again! But the pipeline keeps crashing when I use RGB or RGBA formats. I need this conversion to get the frame in NumPy format using get_nvds_buf_surface and store a JPEG image after all.
Here is my snippet to create the Capsfilter element:
if filter is None:
filter_caps = Gst.Caps.from_string("video/x-raw(memory:NVMM), format=(string)RGB")
I have tried our demo runtime_source_add_delete with the diffs below.
-    nvosd.link(sink)
+    #nvosd.link(sink)
+    nvosd.link(video_converter)
+    video_converter.link(filter)
+    filter.link(sink)
It works properly. Could you refer to that and compare your code?
Also if you want to save jpeg image, you can try to use our API by referring to the FAQ. It will be more efficient.
