I am trying simulate sensor data (camera, IMU and lidar) in Isaac SIM to publish to ROS in a standalone workflow. Is there support to sync publication times, and also manually adjust the frequency? (Eg. I would like the IMU to publish at 400 Hz, and lidar at 10 Hz)
According to this, Isaac SIM should run in real time but with the standalone example
while True:
print('Sim {} Real {}'.format(delta world.current_time, delta time.time()))
# Some synchronous code here
world.step()
Isaac SIM Seems to override the system time to keep 60Hz physics stepping. Is there a overview document or explanation of how timing works in general?
Hi - Sorry for the delay in the response. Let us know if you still having this issue with the latest Isaac Sim 2022.2.1 release.
