Software Version
DRIVE OS 6.0.10.0
[] DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[] Linux
QNX
other
Hardware Platform
[] DRIVE AGX Orin Developer Kit (940-63710-0010-100)
other
SDK Manager Version
2.1.0
other
Host Machine Version
[] native Ubuntu Linux 20.04 Host installed with DRIVE OS Docker Containers
other
Issue Description
Attached a ST Microcontroller to Nvidia Drive AGX Orin , need to perform serial communication via USB to STM Board . Not able to see /dev/ttyUSB0 or /dev/ttyACM0 channel on Drive OS . ST Microcontroller is detected while running “lsusb” command and also detected as Mass storage device while checking dmesg logs . Do we need to install a driver for this or package installation would work
Error String
Not able to see ttyUSB or ttyACM channels
Logs
[ 635.235579] usb 1-3: new full-speed USB device number 9 using tegra-xusb
[ 635.445859] usb-storage 1-3:1.1: USB Mass Storage device detected
[ 635.446101] scsi host0: usb-storage 1-3:1.1
[ 636.452567] scsi 0:0:0:0: Direct-Access MBED microcontroller 1.0 PQ: 0 ANSI: 2
[ 636.453168] sd 0:0:0:0: [sda] 6216 512-byte logical blocks: (3.18 MB/3.04 MiB)
[ 636.453366] sd 0:0:0:0: [sda] Write Protect is off
[ 636.453368] sd 0:0:0:0: [sda] Mode Sense: 03 00 00 00
[ 636.453537] sd 0:0:0:0: [sda] No Caching mode page found
[ 636.453538] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 636.470502] sd 0:0:0:0: [sda] Attached SCSI removable disk
