orin nx 16G
jetpack 5.1.4
你好,
- 我能在应用层去操作i2c eeprom吗?
- 还有我的文件系统中看不到/sys/firmware/devicetree/base/serial-number 这个节点
orin nx 16G
jetpack 5.1.4
你好,
Check below relative topic.
https://forums.developer.nvidia.com/t/orin-series-device-ids-cpu-ids/337928/4
没有回答我的问题呢,
/sys/firmware/devicetree/base/serial-number is not typically generated by a Linux kernel driver. It is a device-tree property that gets populated from the boot firmware / bootloader path, then exposed by the kernel via the flattened device tree filesystem.
What do you mean?
这个怎么暴漏出来?
No, it’s read the EEPROM by the bootloader to handoff to kernel to create it.
