1、Print a garbled log during kernel startup
[ 2.440719] io scheduler bfq registered
[ 2.454282] EINJ: ACPI disabled.
[ 2.465103] tegra264-pmc c800000.pmc: there is not valid maps for state default
[ 2.469436] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 2.471469] msm_serial: driv��[ ��er i�� 2.4��niti��7837��aliz��8] p��ed
��er i��[ ��k: l�� 2.4��egac��7172��y co��3] S��nsol��uper��e [t��H (H��tyUT��)SCI��C0] ��(F) ��enab��driv��led
[ ��niti�� 2.��aliz��4900��ed
��28] ��[ ��prin�� 2.4��tk: ��7336��lega��0] S��cy b��TM32��ootc�� USA��onso��RT d��le [��rive��tegr��r in��a_ut��itia��c0] ��lize��disa��d
[��bled�� ��
[ ��2.47�� 2��8378��.508��] pr��859]��intk�� arm��: le��-smm��gacy��u-v3�� con�� 810��sole��5000�� [tt��000.��yUTC��iomm��0] e��u: i��nabl��as 4��ed
��nsol��[ ��t, o�� 2.4��as 4��9002��8-bi��8] p��t (f��rint��eatu��k: l��res ��egac��0x00��y bo��0e1f��otco��af)
��-v3 8105000000.iommu: allocated 65536 entries for cmdqrm-��isab��smmu��led
[ 2.549332] arm-smmu-v3 8106000000.iommu: ias 48-bit, oas 48-bit (features 0x000e1faf)qs
[ 2.557233] arm-smmu-v3 8106000000.iommu: allocated 65536 entries for cmdq
2、Regularly print garbled logs after system login. Can these garbled logs be prohibited from printing?
mi@localhost:~$
mi@localhost:~$
mi@localhost:~$
mi@localhost:~$
mi@localhost:~$ ��GPC ph => logic map: 0=>0 1=>2 2=>1
��INFO: END TASK:MB��
INFO: enter idle task.
INFO: END TASK:MB��
��ph =��ter idle ta��GPC ��sk.
��> logic map: 0=>0 1=>2 2=>1
mi@localhost:~$
mi@localhost:~$
mi@localhost:~$
INFO: END TASK:MB��
INFO: END TASK:MB��
INFO: END TASK:MB��
INFO: END TASK:MB��
INFO: END TASK:MB��
