I have a NX2 TX on a carrier board from seeed studio (A203V2) and would like to use the uart pins on the J40 header to communicate with a flight controller for a drone.
I am aware that the tx2 nx has multiple serial ports, however the carrier board only makes one available on the header so I am stuck with this one.
Per default, a debugger console seems to sit on this port. The instructions found in this post suggest to disable the serial port in the bpmp configuration file.
# Tegra_for_Linux/bootloader/t186ref/tegra186-bpmp-p3636-0001-a00-00.dts
- serial {
- port = <3>;
- has_input;
Additionally I followed these instructions as well and disabled the debug log in this file:
# tegra186-mb1-bct-misc-si-l4t.cf
debug.enable_log=0;
The next steps were to remove any references to starting a serial console in the kernel cmdline via p3636.conf.common and the ‘chosen’ node in the dtb for the carrier board.
So far it seems to have worked as there no longer is any output printed during boot and sending commands does not cause any response.
Once the system was running I disabled the nvgetty service, added the user to the dialout group and restarted the system to apply the changes.
At this point however I am stuck. I would expect to be able to send and receive from ttyS0 using picocom with a baudrate of 115200.
After connecting a serial to usb converter to the pins, neither sending nor receiving seem to work.
The output from dmesg | grep tty suggests that ttyS0 is running in PIO mode and the group of the tty is dialout, meaning I should have access to it.
sudo dmesg | grep tty
[ 0.000000] Kernel command line: root=PARTUUID=647ac557-cf7c-4c36-bcf1-34caf870ac77 rw rootwait rootfstype=ext4 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=1-2 video=tegrafb nvdumper_reserved=0x1772e0000 gpt rootfs.slot_suffix= tegra_fbmem=0x800000@0x96085000 lut_mem=0x2008@0x96081000 usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 no_console_suspend boot.slot_suffix= boot.ratchetvalues=0.2031647.1 vpr_resize bl_prof_dataptr=0x10000@0x175840000 sdhci_tegra.en_boot_part_access=1 quiet root=PARTUUID=647ac557-cf7c-4c36-bcf1-34caf870ac77 rw rootwait rootfstype=ext4 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=1-2
[ 0.000924] console [tty0] enabled
[ 0.913792] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 32, base_baud = 25500000) is a Tegra
[ 0.914858] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 33, base_baud = 0) is a TEGRA_UART
[ 0.915535] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 34, base_baud = 0) is a TEGRA_UART
[ 0.916279] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 35, base_baud = 0) is a TEGRA_UART
ls -l /dev/ttyS*
crw-rw---- 1 root dialout 4, 64 Nov 24 17:23 /dev/ttyS0
crw-rw---- 1 root dialout 4, 65 Nov 24 17:23 /dev/ttyS1
crw-rw---- 1 root dialout 4, 66 Nov 24 17:23 /dev/ttyS2
crw-rw---- 1 root dialout 4, 67 Nov 24 17:23 /dev/ttyS3
ls -l /dev/ttyT*
crw-rw---- 1 root dialout 4, 143 Nov 24 17:23 /dev/ttyTCU0
crw-rw---- 1 root dialout 238, 1 Nov 24 17:43 /dev/ttyTHS1
crw-rw---- 1 root dialout 238, 2 Nov 24 17:23 /dev/ttyTHS2
crw-rw---- 1 root dialout 238, 3 Nov 24 17:43 /dev/ttyTHS3
I tested the other serial ports as well in case I misunderstood which tty would be available, but neither is responsive. Trying to access the ttys ttyS1, ttyS2 and ttyS3 results in 'FATAL: failed to add device /dev/ttyS1: Filedes is not a tty',
presumably because there are similarly named ttys ttyTHS1, ttyTHS2, ttyTHS3 up with dma already occupying these ports.
I assume they are responsible for the m2 key and the camera module.
Trying to access ttyTCU0 causes the system to hang up and reboot, ttyTHS1, ttyTHS2 and ttyTHS3 all seem unresponsive but at least no crashes.
I have read a plentitude of forum posts regarding this topic but I still find myself lost and would appreciate if you could help me understand where I am going wrong.
If there is any other info I can provide to help please let me know.
