I only enabled video 0 to csi0 data0 now, and for debugging purposes, csi2 data0 csi2 data1 csi3 data0 are all disabled
trace07181611.log (11.8 KB)
dmesg07181611.log (82.8 KB)
tegra234-camera-ox03c10-a00.dtsi (24.3 KB)
Hi, xianfei.chen
Perhaps you can remove the below image dtsi configuration, as it will override your port index configuration.
This dts has been deleted。I put Pix_ Clk_ If hz=“300000000” is set in this way, it will not be able to start. Is our PCLK restricted and unable to receive data? Our PCLK can actually reach over 800000000
I can’t boot up if I refer to this topic configuration
I’m not asking you to delete the file, but to comment out the code where I drew the red box.
We didn’t use this dtsi, attached is our dts
tegra234-p3767-0000-p3509-a02.dts (1.2 KB)
tegra234-p3509-a02.dtsi (5.6 KB)
配置了overlay还是无法正常取图
trace0725.log (16.6 KB)
dmesg0725.log (87.8 KB)
tegra234-p3737-camera-ox03c10-overlay.dts (13.0 KB)
~/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra$ ls kernel/dtb/tegra234-p3737-camera-ox03c10-overlay.dtbo
Does the trace log the same?
Yes ,do you have any suggestions?
Due to the trace log tell didn’t receive any validate data from the sensor.
It could be the HW problem if the port-index/bus-width are correct.
How to determine if overlay is effective
You can dump the device tree to confirm it.
sudo dtc -I fs -O dts -o extracted_proc.dts /proc/device-tree
extracted_proc_R620.dts (552.4 KB)
extracted_proc_s50.dts (421.5 KB)
hi nvidia team
The problem has been resolved, hardware issue. Thank you for your support
