Serious issues with ghosting
Hi all, I am having serious issues with ghosting, the only way I am able to fix this is to raise the items far off the table but I need the items on the table. Can anyone suggest the solution for this, project deadline is tomorrow and I have yet to be able to complete the dataset. There should only be 3 apples in each image. Out of 50 images only 5 do not have this. I have tried disabling Sampled Light etc. I am running on an A40 and also experience constant crashing and need to start new stage every time I want to rerun the code.
Code:
import datetime
basepath = "c:\\Users\\adam\\Desktop\\Omniverse\\Src"
dataset = "Apple"
output_dir = basepath+'\\data\\rendered\\'+datetime.datetime.now().strftime("%Y-%m-%d-%H-%M-%S")+'\\'+dataset
with rep.new_layer():
    TABLE_ASSET = "http://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/ArchVis/Residential/Furniture/DiningSets/EastRural/EastRural_Table.usd"
    FRUIT = {
        "Apple":  "http://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/ArchVis/Residential/Food/Fruit/Apple.usd",
        "Orange":"http://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/ArchVis/Residential/Decor/Tchotchkes/Orange_01.usd",
        "Lime": "http://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/ArchVis/Residential/Food/Fruit/Lime01.usd"
    def table():
        table = rep.create.from_usd(
            TABLE_ASSET, semantics=[('class', 'table')])
        with table:
            rep.physics.collider()
            rep.physics.mass(mass=100)
            rep.modify.pose(
                position=(0, 0, 0),
                rotation=(0, -90, -90),
        return table
    rep.randomizer.register(table)
    def rect_lights(num=1):
        lights = rep.create.light(
            light_type="rect",
            temperature=rep.distribution.normal(6500, 500),
            intensity=rep.distribution.normal(0, 50),
            position=(0, 110, 0),
            rotation=(-90, 0, 0),
            count=num
        return lights.node
    rep.randomizer.register(rect_lights)
    def dome_lights(num=3):
            light_type="dome",
            intensity=rep.distribution.normal(0, 500),
            position=(0, 120, 18),
            rotation=(225, 0, 0),
            count=num
        return lights.node
    rep.randomizer.register(dome_lights)
    def randomize_asset(fpath, fclass, maxnum = 1):
        instances = rep.randomizer.instantiate(
            fpath, size=maxnum, mode='scene_instance')
        with instances:
            rep.modify.semantics([('class', fclass)])
            rep.modify.pose(
                position=rep.distribution.uniform(
                    (-60, 80, -30), (60, 80, 30)),
                rotation=rep.distribution.uniform(
                    (-90, -180, -90), (90, 180, 90))
        return instances.node
    rep.randomizer.register(randomize_asset)
    camera = rep.create.camera(
        position=(0, 200, 0), rotation=(-90, 0, 0))
    render_product = rep.create.render_product(camera, (1024, 1024))
    camera2 = rep.create.camera(
        position=(0, 125, 0), rotation=(-90, 0, 0))
    render_product2 = rep.create.render_product(camera2, (512, 512))
    writer = rep.WriterRegistry.get("BasicWriter")
    writer.initialize(
        output_dir = output_dir,
        rgb=True, bounding_box_2d_tight=True)
    writer.attach([render_product, render_product2])
    with rep.trigger.on_frame(num_frames=50):
        # Table
        rep.randomizer.table()
        # Lights
        rep.randomizer.rect_lights(1)
        rep.randomizer.dome_lights(1)
        # Fruit
        if dataset == "None":
            pass
        elif dataset == "All":
            for fclass, fpath in FRUIT.items():
                rep.randomizer.randomize_asset(fpath, fclass, 3)
        else:
            rep.randomizer.randomize_asset(FRUIT[dataset], dataset, 3)
    rep.orchestrator.run()
It seems to be a combination of issues that make this happen. One is definitely is you try to get a close-up of an object, in this project I needed close-ups, and every attempt failed, as soon as you get closer to the object whether using camera placement or focal length this ghosting happens.
OK so this issue only appears to happen when using RTX Real-Time, so far, changing rendering mode to RTX Interactive (Path Tracing) Seems to allow me to get much closer to subject and no more ghosting, so far. Hope it helps someone.
Hi @AdamMiltonBarkerOfficial I def recommend trying subframes to combat ghosting. Check out the pages here:
Rendering with Subframes Examples — Omniverse Extensions documentation (nvidia.com)
