Brand new DGX Spark. Setting it up via Standalone setup because I can’t see DGX spark hotspot. The set up can’t pass “Connect to Wi-Fi” as Spark keeps looking for available networks, but can’t find any. I get the following message “Error searching for nearby networks. Reason 500”
Hi, I had a similar problem that the DGX Spark cannot see hidden wifi networks. I had to use an ethernet cable. Moreover, there was no way to back out of the menu to search for Wifi Networks, so I had to basically rip the power cord and try again. Terrible setup user experience
Hello, I seem to be having the issue, except that using Ethernet still had no effect. It also does not display the hotspot SSID as well. Has anyone else found a solution or experienced a similar issue?
