Im setting it up using sd card.
Hi, could you please share which version of L4T and JetPack you are using?
Also, will it boot normally if the image is flashed into the internal eMMC instead of an SD card?
I’m closing this topic due to there is no update from you for a period, assuming this issue was resolved.
If still need the support, please open a new topic. Thanks
Is this still an issue to support? Any result can be shared? Thanks
