My Jetson nano board has no J25 Power jack and it is not clear to me if I can still setup my board in headless mode if the J25 power jack is not available. In case yes, how to proceed?
Please check
Log in | NVIDIA Developer
3.4 Automation Header
There is debug UART in J50. You can use the interface to get debug log, and also login the system.
Hi @DaneLLL ,
Sorry, but is it possible or not to perform a headless setup of the Nano board even when the J25 power jack is not present? For me this is not clear from your answer
Best regards
If you don’t supply power from the J25 power jack, you would need to supply it through the USB micro B port. And then login the system through UART. Ideally this setup should be working.
