Hi, I was working with the JETSON NANO, then when I turned it on again: the power LED does not light and the lights of the RJ-45 jack are fixed with and without network cable. Change SD and power supply
Hi cristian_benglenok,
If you use J25 power jack, please connected J48 pins.
Please reference detail from Nano User Guide:
[J48] Enables either J28 Micro-USB connector or J25 power jack as power source for
the developer kit. Without a jumper, the developer kit can be powered by J28 MicroUSB connector. With a jumper, no power is drawn from J28, and the developer kit can be powered via J25 power jack.
my jetson nano only work with J25 and jumper so welcome to the team :) I hope it is no more than that
always work powering the board as seen in the photo, with a 5V and 3A power supply. One day it stops working and when the food can’t find it and it looks like the photo. What is this about? and why should i enable J48? Thanks a lot
You can use jumper to plug-in J48 pin.
