Hello.
I’ve bought the jetson nano B01 Version and now I’m trying to power the board with the Barrel Jack Connector so I can supply 4A @ 5V, which should be plenty for most of my projects. But I have a problem. According with this tutorial :
I should find and install the J48 jumper. The problem is that on my board it is not on the place where it should be (according with the website). Below you can see where it should be :
Instead,below u can see where it is :
the only two pins that I can close with the jumper are the pins of the DC cable (that u see below). Should I detach the red wire rconnector and I should cover those two pins with the yellow jumper that’s inside the box of the nano ? thanks.
