We are currently using the SHT40A-AW1B-R2 humidity sensor with the Jetson Orin Nano. However, we are unable to detect the sensor on the Jetson Orin Nano through the I²C interface.
To verify the hardware, we tested the same sensor with another MCU, and it was detected and communicated successfully.
Could you please help us understand why the sensor is not being detected on the Jetson Orin Nano?
hello shubham.singh21,
may I know which I2C you’re used?
if that’s Jetson Orin Nano developer kit, please refer to 40-pin Expansion Header, it’s actually using I2C1.
you may also check you’ve providing power-supply (3.3V) to your device correctly.
Hello @JerryChang ,
We have tried with both I2C1 and ID_I2C.
For Power supply we are providing it from header only and we have also checked power supply on the input pin of the Sensor.
you may refer to Jetson Orin Nano Developer Kit Carrier Board Specification for [Figure 3-1. Expansion Header Connections].
as you can see.. pin-3/5 from 40-pin expansion header that’s actually module pin-189/191.
please see-also Jetson Orin NX Series and Jetson Orin Nano Series Pinmux. it’s i2c at bus-7.
please try execute.. sudo i2cdetect -y -r 7 for examination.
Hi @JerryChang ,
We have checked with both i2c and also with both frequency 100kHz and 400kHz, but we are not able to detect the Sensor. Please find attched ref img for the same.
just for confirmation, are you working with Jetson Orin Nano developer kit?
Yes it is Jetson Orin Nano Dev Kit.
for Jetson Orin Nano devkit, please connect the sensor to the 40-pin expansion header as following.
pin-1: 3.3V
pin-3: SDA
pin-5: SCL
pin-6: GND
SHT40A-AW1B-R2 should respond at I2C address 0x44, let’s give it a try with.. sudo i2cdetect -y 7 0x44 0x44.
you may also share your wiring schematic, or a clear photo of the sensor connection for troubleshooting.
Hi @JerryChang
Please find attched connection diagrma and Response of IC on above cmd.
it looks strange why $ sudo i2cdetect -y 7 shows nothing.
please also check Configuring the Jetson Expansion Headers to launch Jetson‑IO for reviewing/configuring 40-Pin expansion header.
Hi @JerryChang ,
We have configured this 40-pin header for I2C pins. We have detected another sensor on this bus; the reference image is attached below.
We are not able to detect this specific ic SHT40A
all right, so the i2c-7 on 40-pin expansion header works. it’s the issue on the device side, SHT40A.
you may give it a try for calling i2ctransfer to have some testing,
for instance,
sudo i2ctransfer -y 7 w1@0x44 0xFD
– w1@0x44: write 1 byte to 7-bit I2C address 0x44
– 0xFD: it’s SHT40A high-precision temperature/humidity measurement command.
after that, you should have a short delay, and then read the measurement results.
sudo i2ctransfer -y 7 r6@0x44
– reads 6 bytes from the same SHT40A device at address 0x44.
please also check kernel logs (i.e. sudo dmesg --follow)
if the write command already fails with Remote I/O error, it means the device did not ACK at address 0x44.
hi @JerryChang
as per my understnading i2ctransfer can be used only when device is detected over the i2c bus.
even though, PFA
as you can see, the write command already fails with Remote I/O error, it means the device did not ACK at address 0x44,
you should going to check should the wiring, power, pull-ups, or confirming the exact SHT40A part variant.
Hi @JerryChang
with the same setup we are able to detect it over the stm32. so it is clear that SHT40A is working.
other thing we check is drive strength of i2c pins and can we modifiy it according.
i2c pin drive strength should not the first suspect here. because you can detect another sensor on the same bus 7 at 0x52, the Jetson I2C pinmux and basic pad behavior are probably okay.
please check the actual waveform at the SHT40A pins:
- SDA/SCL idle level should be 3.3V
- SDA/SCL should have clean rising edges
- address 0x44 should show ACK/NACK clearly
- VOL during low should be close to GND
- pull-ups should be to 3.3V, not 5V
