I am unable to download apps from snap store. I have created ubuntu ID, but the Install gets stuck in this screen.
Has anyone faced similar issue? How do I fix it?
Hi rangaresearch,
I have no idea about this, may other developer help to provide suggestions.
I tried updating the packages and rebooting. It didnt work.
I am also unable to run emulators like retroarch and ppsspp which I installed through the terminal. They crash on starting. Once the error message mentioned obsolete packages…
Really need help here…
Here is the log for the issue. After the authentication is success, getting cant initialize nvrm channel
Jun 3 15:47:02 xaviernx nautilus-autostart.desktop[8937]: message repeated 100 times: [ Error: Can't initialize nvrm channel] Jun 3 15:47:04 xaviernx systemd[1]: polkit.service: Main process exited, code=dumped, status=11/SEGV Jun 3 15:47:04 xaviernx systemd[1]: polkit.service: Failed with result 'core-dump'. Jun 3 15:47:04 xaviernx dbus-daemon[5522]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service' requested by ':1.8' (uid=0 pid=5685 comm="/usr/sbin/NetworkManager --no-daemon ") Jun 3 15:47:04 xaviernx polkit-gnome-authentication-agent-1.desktop[8935]: PolicyKit daemon disconnected from the bus. Jun 3 15:47:04 xaviernx polkit-gnome-authentication-agent-1.desktop[8935]: We are no longer a registered authentication agent. Jun 3 15:47:04 xaviernx snapd[5714]: daemon.go:215: polkit error: Message recipient disconnected from message bus without replying Jun 3 15:47:04 xaviernx systemd[1]: Starting Authorization Manager... Jun 3 15:47:04 xaviernx polkitd[23328]: started daemon version 0.105 using authority implementation `local' version `0.105' Jun 3 15:47:04 xaviernx dbus-daemon[5522]: [system] Successfully activated service 'org.freedesktop.PolicyKit1' Jun 3 15:47:04 xaviernx systemd[1]: Started Authorization Manager. Jun 3 15:47:04 xaviernx polkit-gnome-authentication-agent-1.desktop[8935]: PolicyKit daemon reconnected to bus. Jun 3 15:47:04 xaviernx polkit-gnome-authentication-agent-1.desktop[8935]: Attempting to re-register as an authentication agent. Jun 3 15:47:04 xaviernx polkit-gnome-authentication-agent-1.desktop[8935]: We are now a registered authentication agent. Jun 3 15:47:07 xaviernx systemd[1]: polkit.service: Main process exited, code=dumped, status=11/SEGV Jun 3 15:47:07 xaviernx snapd[5714]: daemon.go:215: polkit error: Message recipient disconnected from message bus without replying Jun 3 15:47:07 xaviernx systemd[1]: polkit.service: Failed with result 'core-dump'. Jun 3 15:47:07 xaviernx polkit-gnome-authentication-agent-1.desktop[8935]: PolicyKit daemon disconnected from the bus. Jun 3 15:47:07 xaviernx polkit-gnome-authentication-agent-1.desktop[8935]: We are no longer a registered authentication agent. Jun 3 15:47:07 xaviernx dbus-daemon[5522]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service' requested by ':1.8' (uid=0 pid=5685 comm="/usr/sbin/NetworkManager --no-daemon ") Jun 3 15:47:07 xaviernx systemd[1]: Starting Authorization Manager... Jun 3 15:47:07 xaviernx polkitd[23383]: started daemon version 0.105 using authority implementation `local' version `0.105' Jun 3 15:47:07 xaviernx dbus-daemon[5522]: [system] Successfully activated service 'org.freedesktop.PolicyKit1' Jun 3 15:47:07 xaviernx systemd[1]: Started Authorization Manager. Jun 3 15:47:07 xaviernx polkit-gnome-authentication-agent-1.desktop[8935]: PolicyKit daemon reconnected to bus. Jun 3 15:47:07 xaviernx polkit-gnome-authentication-agent-1.desktop[8935]: Attempting to re-register as an authentication agent. Jun 3 15:47:07 xaviernx polkit-gnome-authentication-agent-1.desktop[8935]: We are now a registered authentication agent. Jun 3 15:47:08 xaviernx nautilus-autostart.desktop[8937]: Error: Can't initialize nvrm channel
Many apps fail throwing the error “Error: Can’t initialize nvrm channel”. What is this issue and is there a fix?
There is a quick solution for this:
Error: Can't initialize nvrm channel - #4 by DaneLLL
Please give it a try.
