I downloaded the driver from Nvidia’s website, transferred it to my linux machine and followed the installation steps (Linux cannot access internet, so it was download to a Windows machine then transferred via USB stick). It says that it installs successfully. But once I reboot, X server says that it cannot start. Looking at the X server output, it says “NVIDIA: No matching Device section for instance…” Also, when I run “lspci | grep -i nvidia” The GPU comes up as “nVidia Corporation Unknown device 13c0 (rev al)” instead of its actual name.
As stated, I’m running Redhat x86 release 5 (Tikanga) and trying to use GTX 980.
If you want your devices to be properly identified, rpm -Uvh the hwdata package from Fedora Rawhide (it won’t break your installation - in fact it contains a textual database of PCI/USB devices).
Are you sure you have just one GPU installed?
(WW) NVIDIA(0): The NVIDIA Quadro NVS 290 GPU installed in this system is
(WW) NVIDIA(0): supported through the NVIDIA 340.xx Legacy drivers. Please
(WW) NVIDIA(0): visit http://www.nvidia.com/object/unix.html for more
(WW) NVIDIA(0): information. The 343.22 NVIDIA driver will ignore this
(WW) NVIDIA(0): GPU. Continuing probe...
From the logs you’ve posted it looks like you have two NVIDIA GPUs and that confuses the driver. Try to specify the GTX 980 PCI location in xorg.conf:
Unfortunately, changing xorg.conf to the above did not fix the issue. Granted, I’ve never messed around with X11 before.
And yes, I have 2 NVIDIA GPUs, the Quadro and the GTX 980. The Quadro came with the PC, and I use it to connect my 2 monitors to the computer. The plan for the GTX 980 is to do some CUDA computation on it. CUDA also is not running properly and wouldn’t detect the GPU without the driver, and now won’t detect any GPU with the driver (gives a devCount of o).
I’ve posted the xorg.conf as well as some other logs/config files that may be helpful.
I did try to use the full format with “PCI:01:00:0” unless I also need to append the “0000:” but I haven’t seen an xorg.conf example that does that (again, I’ve never worked with xorg before).
And I should’ve apologized in advance: I’m in Japan and don’t have internet access on the weekends. That’s why my posting times are so strange and I was absent for a couple days. Thank you for any and all help. xorg.0.2.log (25.3 KB) Xorg.setup.log (1.13 KB) driver.information.log (213 Bytes) driver.registry.log (11 Bytes) xorg.conf.log (1.63 KB)
