Hello Everyone,
I am using Jetson AGX Orin(r35.4.1), I have followed the entire instruction manual, and I still cannot load the firmware on the SPE or I don’t know how to read the logs from SPE.
I added some printf in main.c, but they are missing in the logs.
I think I miss something. I would be grateful for help.
- I have built SPI application, then moved spe_t234.bin to /Linux_for_tegra/bootloader/
- I use this command to flash firmware
sudo ./flash.sh -k A_spe-fw jetson-agx-orin-devkit mmcblk0p1 - using
jetson-demux -d /dev/ttyACM1to access SPE terminal - Logs are saying only something like this.
I> Unhalting SPE..
I> Enabling combined UART
spe: early_init
vic initialized
tsc initialized
aon lic initialized
spe: tag is XXX
spe: SafeRTOS v8.4
spe: init
scheduler initialized
aon hsp initialized
tag initialized
tcu initialized
bpmp ipc initialized
spe: late init
cpu_nic clock initialized
apb clock initialized
pm initialized
bpmp hsp initialized
top1 hsp initialized
ccplex ipc initialized
spe: start scheduler
