Gaosiy
August 23, 2021, 6:52am
1
I use CS signal of SPI1 of xavier. But the CS signal could be pull down completely. The yellow line is CS signal.
I do not know how to deal with it, so I choose use a gpio to replace the CS port.
The code of device tree is
spi@3210000 {
status = "okay";
cs-gpios =<&tegra_aon_gpio TEGRA194_AON_GPIO(AA, 2) GPIO_ACTIVE_LOW>;
ads1299@0 {
compatible = "ads1299";
reg = <0x0>;
spi-max-frequency = <0x1f78a40>;
controller-data {
nvidia,cs-setup-clk-count = <0>;
nvidia,cs-hold-clk-count = <0>;
nvidia,rx-clk-tap-delay = <0>;
nvidia,tx-clk-tap-delay = <0>;
And I got the CS pull down well
But when I contorl some property of spi_transfer
struct spi_transfer tr =
.tx_buf = &t0,
.len = 1,
.cs_change = 0,
.delay_usecs = 2,
The cs_change and the delay_usecs does not work, I need set a delay between a spi transfer , so now the situation does not solve my problem, could you give me some advice to deal with it?
Gaosiy
August 23, 2021, 6:55am
2
I add the picture directly.
use spi cs0
use gpio250 as CS
kayccc
August 23, 2021, 11:53pm
5
We will investigate this issue and do the update soon. Thanks
Gaosiy
August 24, 2021, 1:29am
6
Thank you kay, How can I check the update, will you notice me in at this topic?
@Gaosiy
Could you confirm change the compatible string in the device tree to “nvidia,tegra194-spi” this would enable the cs_active_delay_hw flag support.
Gaosiy
September 16, 2021, 8:34am
8
Hi Shane, is this flag control the delay between to bytes in one spi transfer?
In my question,
.tx_buf = &t0,
.len = 1,
.cs_change = 0,
.delay_usecs = 2,
the delay_usecs did not work.
The cs_active_delay_hw should be the one define in device tree.
Have a check below property to trace the driver to figure it out.
of_property_read_u32(data_np, "nvidia,cs-setup-clk-count",
1231 &cdata->cs_setup_clk_count);
1232 of_property_read_u32(data_np, "nvidia,cs-hold-clk-count",
1233 &cdata->cs_hold_clk_count);
1234 of_property_read_u32(data_np, "nvidia,rx-clk-tap-delay",
1235 &cdata->rx_clk_tap_delay);
1236 of_property_read_u32(data_np, "nvidia,tx-clk-tap-delay",
1237 &cdata->tx_clk_tap_delay);
1238 ret = of_property_read_u32(data_np, "nvidia,cs-inactive-cycles",
1239 &cdata->clk_delay_between_packets);
1240 if (!ret)
1241 cdata->is_cs_delay_inactive = 1;
1242
1243 /* clk_delay_between_packets is delay cycles active or inactive */
1244 ret = of_property_read_u32(data_np, "nvidia,clk-delay-between-packets",
1245 &cdata->clk_delay_between_packets);
1246 if (!ret)
1247 /* is_cs_delay_inactive is used to decide cs active or inactive */
1248 cdata->is_cs_delay_inactive = 0;
Gaosiy
September 16, 2021, 8:49am
10
I know, I mean what is the function of this item, I found no related in the binding doc tegra114spi
Gaosiy
September 17, 2021, 1:20am
11
Thanks Shane, by using this item, I have a delay between bytes.
