SSH File Transfer Issue from Windows 11 PC to Jetson Orin Nano via USB-C - Ping Disconnections
hello.
I am attempting to transfer files via SSH from my Windows 11 PC to my Jetson Orin Nano, connected directly via a USB-C cable.
However, I am encountering an issue where the connection drops intermittently when I use the ping command. This disconnection is preventing stable SSH file transfers.
ping_output.txt (873 Bytes)
Could you please provide any potential solutions or troubleshooting steps to resolve this connectivity problem?
Thank you for your time and assistance.
Sincerely,
ryoya.shimizu
To address the issue of intermittent connection drops when attempting to transfer files via SSH from your computer to your Jetson Orin Nano, which is connected directly via a USB-C cable, several potential solutions and troubleshooting steps can be considered. The Jetson Orin Nano, being a powerful platform for AI computing and embedded systems, relies on stable connections for efficient data transfer and development. Here are some steps to help resolve the connectivity problem:
  1. Check the USB-C Cable and Connection:
    • Ensure that the USB-C cable is securely connected to both your computer and the Jetson Orin Nano. A loose connection can cause intermittent drops.
    • Try using a different USB-C cable to rule out any issues with the current cable.
  2. Power Supply:
    • The Jetson Orin Nano requires a stable power supply. If you’re powering it via the USB-C cable, ensure that your computer’s USB port can supply enough power. Consider using an external power adapter if necessary.
    • Power issues can lead to instability in the connection.
  3. USB-C Port Configuration:
    • Some USB-C ports might be configured for data transfer only, without power delivery or vice versa. Ensure the port you’re using supports both data and power (if needed).
    • If your computer has multiple USB-C ports, try using a different port to see if the issue persists.
  4. Driver Updates:
    • Ensure that your computer’s USB drivers are up to date. Outdated drivers can cause connectivity issues.
    • For the Jetson Orin Nano, check if there are any firmware updates available that might improve USB connectivity.
  5. SSH Connection Settings:
    • Adjust your SSH connection settings to use a more reliable protocol or to keep the connection alive. For example, you can use the ServerAliveInterval and ServerAliveCountMax settings in your SSH client configuration to send keepalive messages.
    • Example: ssh -o "ServerAliveInterval 60" -o "ServerAliveCountMax 30" user@jetson-orin-nano-ip
  6. Network Configuration:
    • If you’re using a network over USB (e.g., USB Ethernet/RNDIS), ensure that the network settings are correctly configured on both your computer and the Jetson Orin Nano.
    • Try setting a static IP address for the Jetson Orin Nano to avoid any DHCP-related issues.
  7. Alternative Transfer Methods:
    • Consider using alternative file transfer methods such as scp or rsync which might be more resilient to connection drops.
    • Example: scp -o "ServerAliveInterval 60" localfile user@jetson-orin-nano-ip:/remotefile
  8. Debugging:
    • Enable verbose mode for SSH to get more detailed output about the connection process. This can help identify where the connection is dropping.
    • Example: ssh -v user@jetson-orin-nano-ip
  9. Comparison with Other Jetson Models:
    • If possible, try the same setup with a different Jetson model (like Jetson Orin NX or Jetson AGX Orin) to see if the issue is specific to the Jetson Orin Nano.
    • This can help determine if the problem is hardware-specific or related to the Jetson Orin Nano’s configuration.
  10. Official Support and Forums:
    • Check NVIDIA’s official forums and support pages for the Jetson Orin Nano. There might be known issues or patches available that address connectivity problems.
    • The community forums can also be a valuable resource for troubleshooting tips from other users who might have encountered similar issues.
By systematically going through these steps, you should be able to identify and potentially resolve the intermittent connection drops affecting your SSH file transfers to the Jetson Orin Nano.
It appears to be stable in our tests using a host running Ubuntu.
Please connect your Orin Nano to Ethernet and try transferring data.
Hi, DavidDDD.
Thank you for your previous assistance.
If it’s absolutely necessary for me to continue working from a Windows PC (Windows 11 in my case) for SSH communication and file transfer with the Jetson Orin Nano, are there any specific strategies, configurations, or recommended tools that could help overcome the connectivity challenges I’ve been experiencing?
I am looking for practical advice or alternative approaches that can enable stable and reliable communication in a Windows environment, given that moving to a Linux-based setup is not feasible for my current workflow.
Any guidance on this would be greatly appreciated.
Sincerely,
Hi shimizu.ryoya,
I understand your situation.
Instead of using 192.168.55.1 , please connect your Orin Nano to the local network via Ethernet and use SSH or SCP to connect through its local IP address (for example, 10.x.x.x ).
