Issue SSH-ing into Orin Nano
Newbie here so I appreciate your patience,
I’m attempting to SSH into my Orin Nano via a Windows Machine using PuTTY. I have updated to Jetpack 6.1 as well as the Orin Firmware and enabled SSH on the Orin side, however it still won’t connect. I am using the same process that I was using previously with the Jetson Nano however it won’t detect any connection, the connection simply times out.
I have no issue connecting via Serial or with a Nano Previously. I haven’t used any of the pin jumpers yet but am using Barrel Power to power the Orin.
This hasn’t been a problem for me previously so I’m wanting to know if there’s something I could be missing in terms of being Orin specific.
Thank you for your help.
Generally we connect to Jetson device through ethernet. Please make sure the device and the Windows host are in same LAN(local area network) and IP address of the Jetson device is correct in the ssh command.
