I have flash with minimal rootfs jetpack 5.1.2 with disk encryption, but i’m not able to ssh 192.168.55.1
without disk encryption i’m able to ssh 192.168.55.1
Hi mrcloud,
Are you using the devkit or custom board for Orin Nano?
Do you connect USB from Orin Nano to your host?
Please share the result of ifconfig on your board for further check.
Hi Kevin
I’m using both board.
I connect the USB to Orin nano.
I’m using minimal focal, there is no GUI for me to access also I’m not able to use USB 192.168.55.1 to connect to the board. with disk encryption. Without disk encryption I’m able to do it through USB ssh192.168.55.1
Check this on the serial console.
Stuff like I'm not able to... doesn’t help anything.
It seems there’s not the entry like l4tbr0 so that you can’t access the board through 192.168.55.1.
What do yo get from dmesg when you plug in the flashing cable?
