Hi, I’m trying to migrate from Isaac Sim 2022.1.1 to the latest 2022.2.0. I started a new AWS instance and pulled the container, and I am able to run it. The command ./runheadless.native.sh
to launch the streaming application works fine, but if I try to run any standalone examples, i.e., by running:
./python.sh ./standalone_examples/api/omni.isaac.kit/livestream.py
I get a segmentation fault. The logs and terminal output say:
2023-02-23 23:17:36 [1,964ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_EXTENSION_NOT_PRESENT
2023-02-23 23:17:36 [1,964ms] [Error] [carb.graphics-vulkan.plugin] vkCreateInstance failed. Vulkan 1.1 is not supported, or your driver requires an update.
2023-02-23 23:17:36 [1,964ms] [Error] [gpu.foundation.plugin] carb::graphics::createInstance failed.
2023-02-23 23:17:36 [1,964ms] [Error] [omni.gpu_foundation_factory.plugin] Failed to create GPU foundation devices!
I am using a clean setup of the most recent NVIDIA Omniverse AMI for AWS. What is causing this error? For reference, my NVIDIA driver info (from nvidia-smi
) is:
| NVIDIA-SMI 525.60.11 Driver Version: 525.60.11 CUDA Version: 12.0 |
| | | MIG M. |
| 0 NVIDIA A10G Off | 00000000:00:1E.0 Off | 0 |
| 0% 23C P0 59W / 300W | 0MiB / 23028MiB | 0% Default |
| | | N/A |
