Try launch ./python.sh standalone_examples/api/omni.isaac.kit/livestream.py
I have installed Isaac Sim container (v 2022.2.1) on a personal server equipped with a Quadro RTX 5000.
When I launch ./python.sh standalone_examples/api/omni.isaac.kit/livestream.py everything works fine until I try to launch Omniverse Streaming Client.
When I click on connect I see a black window and the message :
./python.sh: line 41: 603 Segmentation fault (core dumped) $python_exe "$@" $args
is printed on docker terminal
Hi @Leopold_M - Can you share the complete log file to debug further?
Also, there is a documentation for Know Issues for your reference: Known Issues — Omniverse Robotics documentation
log_error_streaming.txt (25.0 KB)
Hello, thank you for your answer. I enclose the logs, I hope they are the ones you want.
Also when I launch./runheadless.native.sh streaming works normally.
Hi. Please try this patch:
Thanks a lot for your help.
It works perfectly well now. I can connect the streaming client successfully
