Software Version
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.2.10884
other - 1.9.3.10904
Host Machine Version
other
Hi, we are trying to get the sample camera replay running and are running into an error (seen below). We generated the sample cross compilation files following the “Samples Cross-Compilation From Source” section from this link DriveWorks SDK Reference: Getting Started Using the NVIDIA SDK Manager
We moved the resulting bin files over to the Orin device and were able to run the sample_hello_world file successfully, but we are running into an error reporting “std::bad_array_new_length”.
nvidia-cam@tegra-ubuntu:/usr/local/driveworks/samples/bin$ sudo ./sample_camera_replay --video=/usr/local/driveworks/data/samples/recordings/highway0/video_first.h264
[sudo] password for nvidia-cam:
ProgramArguments: Missing argument 'dwTracePath' requested
terminate called after throwing an instance of 'std::bad_array_new_length'
what(): std::bad_array_new_length
Aborted
We are currently using nomachine to view the desktop of the device and to run this application. Thank you, please let me know if there’s anything we should try to fix.
Note we tried to run this with and without sudo and reported the same error.
