Dear all:
cant use SDK manager cause custom carrier board
using the command line(in file Setup.sh) below can only update to tensorrt 5.1.2.
any idea why this happened?
env->jetson orin nx 8GB with jetpack 5.1.2
log->run_Setup_sh_file_log.txt
run_Setup_sh_file_log.txt (172.2 KB)
#!/bin/bash
sudo apt clean
shellcheck disable=SC2046
DIR=$(cd $(dirname “$0”) && pwd )
sudo cp $DIR/nvidia-l4t-apt-source.list /etc/apt/sources.list.d/
sudo apt update
sudo apt upgrade -y
sudo apt dist-upgrade -y
echo y | sudo apt install nvidia-jetpack
echo y | sudo apt-get install python3-dev
echo y | sudo apt install python3-pip
echo y | sudo -H pip3 install -U jetson-stats
echo y | sudo apt install efibootmgr
sudo apt clean
sudo reboot
