I use Jetson Nano Developer Kit 4GB and Raspberry Pi HQ camera. I tried streaming video but system frezess and reboots.
System info:
Jetpack 4.6.1
IMX477 driver (from ArduCAM)
Output on console when system freezes:
gst-launch-1.0 nvarguscanerasrc I nvoverlaystnk
Settlng pipeline to PAUSED …
Pipeline ls live and does not need PREROLL
Setting pipeline to PLAYING …
New clock: GstSystenclock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer ls connected…
GST_ARGUS: Available Sensor nodes
GST_ARGUS: 3840 x 2160 FR - 29,999999 fps Duration = 33333334 ; Analog Gain rang
e min 1,000000, max 22,250000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 59,999999 fps Duration 16666607 Analog Gain range min 1,000000, max 22,250000; Exposure Range min 13000, nax 693709000;
GST_ARGUS: Running with following settings:
Camera lndex 0
Camera mode a1
Output Stream W = 1920 H = 1080
seconds to Run = 0
Frame Rate = 59,999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
Thanks, the camera worked. But I can’t close the camera. It takes up the entire screen. Keyboard shortcuts (CTRL + ALT + T etc.) don’t work. How can I close it?
