When I run gst-launch-1.0 , system freezes and reboot
I have a Jetson Nano Development Kit with the camera IMX219-77_Camera(IMX219-77 Camera - Waveshare Wiki) installed. Also, I installed the last jetson nano image in the system (jetson-nano-jp461-sd-card-image.zip)
When I look for the device, it is in /dev/video0, however when I try to run the following command:
DISPLAY=:0.0 gst-launch-1.0 nvarguscamerasrc ! ‘video/x-raw(memory:NVMM), width=3280, height=2464, format=(string)NV12, framerate=(fraction)20/1’ ! nvoverlaysink -e
System get freeze and after 10~20 seconds it reboots. I ran the above command with another terminal opened with the command: journalctl -f and I have been able to take a snapshot before it reboots.
Do you know how could I figure it out?
Please check if you can run this command successfully:
$ gst-launch-1.0 nvarguscamerasrc ! nvoverlaysink
If it does not work, please contact the vendor to check the sensor driver.
Or you may try Raspberry Pi camera V2. It is supported by default.
