System Setup Jetson TX2
Hello everybody,
I want to setup TX2 on Ubuntu with this document: GitHub - dusty-nv/jetson-inference: Hello AI World guide to deploying deep-learning inference networks and deep vision primitives with TensorRT and NVIDIA Jetson.
But My program failed when I install nvidia-docker2. I’m tried by something on google but not success.
So Can you have me a exactly document for setup Jetson TX2?
Thank you very much!
Hi letrung096, the Docker portion of the tutorial is for installing in the cloud or a host PC, for setting up the training machine. Your Jetson TX2 gets JetPack installed to it if you haven’t already done so.
The neural network training is done on a server or PC that has a larger GPU and larger disk, and then the network model is deployed to the Jetson which runs inferencing with TensorRT.
Hello Nvidia’s supporter. I’m thank you for your response.
I installed Jetpack but I still not can install nvidia-docker2. So I can’t install Digit server. Wish response soon.
Thank you!
Please use DIGITs on the cloud or host PC(x86 based environment).
It cannot be used on the Jetson platform.
Maybe I found problem.
I tried to download nvidia-docker from https://nvidia.github.io/nvidia-docker/$distribution/nvidia-docker.list follow code:
curl -s -L https://nvidia.github.io/nvidia-docker/$distribution/nvidia-docker.list |
sudo tee /etc/apt/sources.list.d/nvidia-docker.list
sudo apt-get update
[GitHub - NVIDIA/nvidia-docker: Build and run Docker containers leveraging NVIDIA GPUs]
but in reality, this link can not access :((
why I can’t access nvidia-docker2 for jetson tx2?
I understood. Because I use Jetson TX2, this use arm so not support by DIGITs.
Can you give me difference way to setup DIGITs for Jetson TX2?
thank you very much!
DIGITs cannot be used on the TX2 due to some required tool is not supported(ex.nvidia-smi) .
In general, it’s NOT recommended to use Jetson for training. You may face issues on the limited storage and bandwidth.
If this is essential for you, you can try to setup Caffe/TensorFlow on Jetson directly.
