Hi NVIDIA team,
We are experiencing RTC date/time loss on our Jetson T5000 module and believe it is caused by erratum RTC-1 in Jetson Thor Modules Hardware Errata DA-12711-001_v02, addressed by PCN 213441.
Module: Jetson T5000, OPN 900-13834-0080-000, pre-PCN213441 revision
Symptom:
After the system time is set, it is kept across some reboots, but after further power cycles or an abnormal shutdown the RTC loses the date/time and the system comes up with an incorrect (reset) date. This matches the RTC-1 description of the PMIC RTC failing to retain date and time over a power cycle.
Diagnostics attached:
cat /etc/nv_boot_control.conf(module revision)cat /etc/nv_tegra_release(Jetson Linux version)sudo hwclock -randls -l /dev/rtc*sudo dmesg | grep -i rtc
Request:
- Please confirm this issue is caused by erratum RTC-1 / PCN 213441.
- Please confirm the module is eligible for replacement with the updated revision, so our distributor can process the RMA.
Thank you.
