Hello, flashing custom auvidea board jnx45 jetson orin nano with jetpack 6.2, though here custom board does not matter since it is about tegraparser_v2 in bootloader directory. External device is 4TB, luks encryption is enabled, number of sectors is 8001573552 and app enc size is 4093758144512, which is precisely 3813GiB(as supplied to flashing script) minus 419430400 as per script and xml file, here’s calculation from gdb
(gdb) p 3813ULL*1024ULL*1024ULL*1024ULL-419430400ULL
$2 = 4093758144512
attaching xml file as partition.txt.
partition.txt (9.4 KB)
During flash process when tegraflash.py script is invoked in bootloader it uses that xml file(which is itself outputted from flash.sh), to output bin file then from that bin file gpt, using these commands
[ 0.0402 ] tegraparser_v2 --pt flash.xml.tmp
[ 8.2278 ] tegraparser_v2 --generategpt --pt flash.xml.bin
Using these commands on attached xml file will give wrong result for partition size, it will give
gpt_primary_9_0.bin:
partition_id partition_name StartingLba EndingLba
1 APP 3050048 3869247
2 APP_ENC 3869248 3704523327
3 A_kernel 40 262183
4 A_kernel-dtb 262184 263719
5 A_reserved_on_user 263720 328487
6 B_kernel 328488 590631
7 B_kernel-dtb 590632 592167
8 B_reserved_on_user 592168 656935
9 recovery 656936 820775
10 recovery-dtb 820776 821799
11 esp 821800 952871
12 recovery_alt 952872 1116711
13 recovery-dtb_alt 1116712 1117735
14 esp_alt 1117736 1248807
15 UDA 1248832 2068031
16 reserved 2068032 3050047
gpt_secondary_9_0.bin:
For app_enc which is
(gdb) p (3704523327ULL-3869248ULL)*512ULL
$3 = 1894734888448
(gdb) p (1894734888448ULL/1024ULL/1024ULL/1024ULL)
$4 = 1764
(gdb) p (1894734888448ULL/1000ULL/1000ULL/1000ULL)
$5 = 1894
1764 GiB or 1894GB which is what is seen during flashing
Number Start End Size File system Name Flags
3 20.5kB 134MB 134MB A_kernel msftdata
4 134MB 135MB 786kB A_kernel-dtb msftdata
5 135MB 168MB 33.2MB A_reserved_on_user msftdata
6 168MB 302MB 134MB B_kernel msftdata
7 302MB 303MB 786kB B_kernel-dtb msftdata
8 303MB 336MB 33.2MB B_reserved_on_user msftdata
9 336MB 420MB 83.9MB recovery msftdata
10 420MB 421MB 524kB recovery-dtb msftdata
11 421MB 488MB 67.1MB fat32 esp boot, esp
12 488MB 572MB 83.9MB recovery_alt msftdata
13 572MB 572MB 524kB recovery-dtb_alt msftdata
14 572MB 639MB 67.1MB esp_alt msftdata
15 639MB 1059MB 419MB UDA msftdata
16 1059MB 1562MB 503MB reserved msftdata
1 1562MB 1981MB 419MB ext4 APP msftdata
2 1981MB 1897GB 1895GB APP_ENC msftdata
Now, the problem with tegraparser_v2 is that in function NvTegraParserPartitionLayout num_sectors is unsigned long so value is truncated, using gdb for the next section it shows what happened
.text:0804A335 mov [esp+8Ch+var_88], offset aNumSectors ; "num_sectors"
.text:0804A33D mov eax, [esp+8Ch+var_60]
.text:0804A341 mov [esp+8Ch+var_8C], eax
.text:0804A344 call NvTegraXmlAttribute
.text:0804A349 test eax, eax
.text:0804A34B jz short loc_804A373
.text:0804A34D mov [esp+8Ch+var_84], 0
.text:0804A355 mov [esp+8Ch+var_88], 0
.text:0804A35D mov [esp+8Ch+var_8C], eax
.text:0804A360 call strtoul
.text:0804A365 mov edx, [esp+8Ch+var_64]
.text:0804A369 mov [edx+10h], eax
.text:0804A36C mov dword ptr [edx+14h], 0
(gdb) p (const char*)$eax
$19 = 0x80d6de0 "8001573552"
(gdb) ni
0x0804a365 in NvTegraParserPartitionLayout ()
(gdb) p $eax
$20 = -1
(gdb) p (unsigned long)$eax
$21 = 4294967295
Here $19 is before call strtoul so num sectors is that which was supplied in the start of this post, then after stroul it is ULONG_MAX at $21, so then it stores that value in class or struct variable i guess and goes along with it. Maybe i am missing something but it seems that disks with more than 4294967295 sectors do not work properly as main boot disk?
