Tensorrt Error for OCDNet
Description
A clear and concise description of the bug or issue.
Environment
TensorRT Version : 10.6.0.26-1+cuda12.6
GPU Type : rtx 4070ti
Nvidia Driver Version : 550.120
CUDA Version : 12.6
Operating System + Version : Ubuntu 22.04
Python Version (if applicable) : 3.10
I’m using OCDNet deployable onnx file: ocdnet_fan_tiny_2x_icdar_pruned.onnx from OCDNet file browser
However, when converting to engine using the below command:
/usr/src/tensorrt/bin/trtexec --onnx=./ocdnet_fan_tiny_2x_icdar_pruned.onnx --minShapes=input:1x3x736x1280 --optShapes=input:1x3x736x1280 --maxShapes=input:4x3x736x1280 --fp16 --saveEngine=./ocdnet.fp16.engine
I get the following error:
[11/08/2024-16:33:48] [I] === Model Options ===
[11/08/2024-16:33:48] [I] Format: ONNX
[11/08/2024-16:33:48] [I] Model: ./ocdnet_fan_tiny_2x_icdar_pruned.onnx
[11/08/2024-16:33:48] [I] Output:
[11/08/2024-16:33:48] [I] === Build Options ===
[11/08/2024-16:33:48] [I] Memory Pools: workspace: default, dlaSRAM: default, dlaLocalDRAM: default, dlaGlobalDRAM: default, tacticSharedMem: default
[11/08/2024-16:33:48] [I] avgTiming: 8
[11/08/2024-16:33:48] [I] Precision: FP32+FP16
[11/08/2024-16:33:48] [I] LayerPrecisions:
[11/08/2024-16:33:48] [I] Layer Device Types:
[11/08/2024-16:33:48] [I] Calibration:
[11/08/2024-16:33:48] [I] Refit: Disabled
[11/08/2024-16:33:48] [I] Strip weights: Disabled
[11/08/2024-16:33:48] [I] Version Compatible: Disabled
[11/08/2024-16:33:48] [I] ONNX Plugin InstanceNorm: Disabled
[11/08/2024-16:33:48] [I] TensorRT runtime: full
[11/08/2024-16:33:48] [I] Lean DLL Path:
[11/08/2024-16:33:48] [I] Tempfile Controls: { in_memory: allow, temporary: allow }
[11/08/2024-16:33:48] [I] Exclude Lean Runtime: Disabled
[11/08/2024-16:33:48] [I] Sparsity: Disabled
[11/08/2024-16:33:48] [I] Safe mode: Disabled
[11/08/2024-16:33:48] [I] Build DLA standalone loadable: Disabled
[11/08/2024-16:33:48] [I] Allow GPU fallback for DLA: Disabled
[11/08/2024-16:33:48] [I] DirectIO mode: Disabled
[11/08/2024-16:33:48] [I] Restricted mode: Disabled
[11/08/2024-16:33:48] [I] Skip inference: Disabled
[11/08/2024-16:33:48] [I] Save engine: ./ocdnet.fp16.engine
[11/08/2024-16:33:48] [I] Load engine:
[11/08/2024-16:33:48] [I] Profiling verbosity: 0
[11/08/2024-16:33:48] [I] Tactic sources: Using default tactic sources
[11/08/2024-16:33:48] [I] timingCacheMode: local
[11/08/2024-16:33:48] [I] timingCacheFile:
[11/08/2024-16:33:48] [I] Enable Compilation Cache: Enabled
[11/08/2024-16:33:48] [I] Enable Monitor Memory: Disabled
[11/08/2024-16:33:48] [I] errorOnTimingCacheMiss: Disabled
[11/08/2024-16:33:48] [I] Preview Features: Use default preview flags.
[11/08/2024-16:33:48] [I] MaxAuxStreams: -1
[11/08/2024-16:33:48] [I] BuilderOptimizationLevel: -1
[11/08/2024-16:33:48] [I] MaxTactics: -1
[11/08/2024-16:33:48] [I] Calibration Profile Index: 0
[11/08/2024-16:33:48] [I] Weight Streaming: Disabled
[11/08/2024-16:33:48] [I] Runtime Platform: Same As Build
[11/08/2024-16:33:48] [I] Debug Tensors:
[11/08/2024-16:33:48] [I] Input(s)s format: fp32:CHW
[11/08/2024-16:33:48] [I] Output(s)s format: fp32:CHW
[11/08/2024-16:33:48] [I] Input build shape (profile 0): input=1x3x736x1280+1x3x736x1280+2x3x736x1280
[11/08/2024-16:33:48] [I] Input calibration shapes: model
[11/08/2024-16:33:48] [I] === System Options ===
[11/08/2024-16:33:48] [I] Device: 0
[11/08/2024-16:33:48] [I] DLACore:
[11/08/2024-16:33:48] [I] Plugins:
[11/08/2024-16:33:48] [I] setPluginsToSerialize:
[11/08/2024-16:33:48] [I] dynamicPlugins:
[11/08/2024-16:33:48] [I] ignoreParsedPluginLibs: 0
[11/08/2024-16:33:48] [I] === Inference Options ===
[11/08/2024-16:33:48] [I] Batch: Explicit
[11/08/2024-16:33:48] [I] Input inference shape : input=1x3x736x1280
[11/08/2024-16:33:48] [I] Iterations: 10
[11/08/2024-16:33:48] [I] Duration: 3s (+ 200ms warm up)
[11/08/2024-16:33:48] [I] Sleep time: 0ms
[11/08/2024-16:33:48] [I] Idle time: 0ms
[11/08/2024-16:33:48] [I] Inference Streams: 1
[11/08/2024-16:33:48] [I] ExposeDMA: Disabled
[11/08/2024-16:33:48] [I] Data transfers: Enabled
[11/08/2024-16:33:48] [I] Spin-wait: Disabled
[11/08/2024-16:33:48] [I] Multithreading: Disabled
[11/08/2024-16:33:48] [I] CUDA Graph: Disabled
[11/08/2024-16:33:48] [I] Separate profiling: Disabled
[11/08/2024-16:33:48] [I] Time Deserialize: Disabled
[11/08/2024-16:33:48] [I] Time Refit: Disabled
[11/08/2024-16:33:48] [I] NVTX verbosity: 0
[11/08/2024-16:33:48] [I] Persistent Cache Ratio: 0
[11/08/2024-16:33:48] [I] Optimization Profile Index: 0
[11/08/2024-16:33:48] [I] Weight Streaming Budget: 100.000000%
[11/08/2024-16:33:48] [I] Inputs:
[11/08/2024-16:33:48] [I] Debug Tensor Save Destinations:
[11/08/2024-16:33:48] [I] === Reporting Options ===
[11/08/2024-16:33:48] [I] Verbose: Disabled
[11/08/2024-16:33:48] [I] Averages: 10 inferences
[11/08/2024-16:33:48] [I] Percentiles: 90,95,99
[11/08/2024-16:33:48] [I] Dump refittable layers:Disabled
[11/08/2024-16:33:48] [I] Dump output: Disabled
[11/08/2024-16:33:48] [I] Profile: Disabled
[11/08/2024-16:33:48] [I] Export timing to JSON file:
[11/08/2024-16:33:48] [I] Export output to JSON file:
[11/08/2024-16:33:48] [I] Export profile to JSON file:
[11/08/2024-16:33:48] [I] === Device Information ===
[11/08/2024-16:33:48] [I] Available Devices:
[11/08/2024-16:33:48] [I]   Device 0: "NVIDIA GeForce RTX 4070 Ti" UUID: GPU-f8485527-9b53-b0a8-239f-c915b1080531
[11/08/2024-16:33:48] [I] Selected Device: NVIDIA GeForce RTX 4070 Ti
[11/08/2024-16:33:48] [I] Selected Device ID: 0
[11/08/2024-16:33:48] [I] Selected Device UUID: GPU-f8485527-9b53-b0a8-239f-c915b1080531
[11/08/2024-16:33:48] [I] Compute Capability: 8.9
[11/08/2024-16:33:48] [I] SMs: 60
[11/08/2024-16:33:48] [I] Device Global Memory: 11996 MiB
[11/08/2024-16:33:48] [I] Shared Memory per SM: 100 KiB
[11/08/2024-16:33:48] [I] Memory Bus Width: 192 bits (ECC disabled)
[11/08/2024-16:33:48] [I] Application Compute Clock Rate: 2.625 GHz
[11/08/2024-16:33:48] [I] Application Memory Clock Rate: 10.501 GHz
[11/08/2024-16:33:48] [I] Note: The application clock rates do not reflect the actual clock rates that the GPU is currently running at.
[11/08/2024-16:33:48] [I] TensorRT version: 10.6.0
[11/08/2024-16:33:48] [I] Loading standard plugins
[11/08/2024-16:33:48] [I] [TRT] [MemUsageChange] Init CUDA: CPU +2, GPU +0, now: CPU 20, GPU 545 (MiB)
[11/08/2024-16:33:49] [I] [TRT] [MemUsageChange] Init builder kernel library: CPU +2275, GPU +436, now: CPU 2451, GPU 981 (MiB)
[11/08/2024-16:33:49] [I] Start parsing network model.
[11/08/2024-16:33:49] [I] [TRT] ----------------------------------------------------------------
[11/08/2024-16:33:49] [I] [TRT] Input filename:   ./ocdnet_fan_tiny_2x_icdar_pruned.onnx
[11/08/2024-16:33:49] [I] [TRT] ONNX IR version:  0.0.8
[11/08/2024-16:33:49] [I] [TRT] Opset version:    17
[11/08/2024-16:33:49] [I] [TRT] Producer name:    pytorch
[11/08/2024-16:33:49] [I] [TRT] Producer version: 1.14.0
[11/08/2024-16:33:49] [I] [TRT] Domain:
[11/08/2024-16:33:49] [I] [TRT] Model version:    0
[11/08/2024-16:33:49] [I] [TRT] Doc string:
[11/08/2024-16:33:49] [I] Finished parsing network model. Parse time: 0.0516525
[11/08/2024-16:33:49] [I] Set shape of input tensor input for optimization profile 0 to: MIN=1x3x736x1280 OPT=1x3x736x1280 MAX=2x3x736x1280
[11/08/2024-16:33:50] [I] [TRT] Local timing cache in use. Profiling results in this builder pass will not be stored.
[11/08/2024-16:33:51] [I] [TRT] Compiler backend is used during engine build.
[11/08/2024-16:35:27] [W] [TRT] UNSUPPORTED_STATE: Skipping tactic 0 due to insufficient memory on requested size of 27825274880 detected for tactic 0x0000000000000000.
[11/08/2024-16:35:45] [W] [TRT] UNSUPPORTED_STATE: Skipping tactic 0 due to insufficient memory on requested size of 27847884800 detected for tactic 0x0000000000000000.
[11/08/2024-16:35:48] [W] [TRT] UNSUPPORTED_STATE: Skipping tactic 0 due to insufficient memory on requested size of 27847884800 detected for tactic 0x0000000000000000.
[11/08/2024-16:35:49] [W] [TRT] UNSUPPORTED_STATE: Skipping tactic 0 due to insufficient memory on requested size of 27847884800 detected for tactic 0x0000000000000000.
[11/08/2024-16:35:50] [W] [TRT] UNSUPPORTED_STATE: Skipping tactic 0 due to insufficient memory on requested size of 27847884800 detected for tactic 0x0000000000000000.
[11/08/2024-16:35:51] [W] [TRT] UNSUPPORTED_STATE: Skipping tactic 0 due to insufficient memory on requested size of 27847884800 detected for tactic 0x0000000000000000.
Any suggestion on this @Morganh
Moving to TAO forum since it is related to TAO model.
It is due to the insufficient GPU memory. For ocdnet_fan_tiny_2x_icdar_pruned.onnx, it is suggest to use more than 12G GPU memory. You can try another dgpu or use non-vit models to try. For example, deformable_resnet50 onnx model.
