Hello I appreciate any and all assistance with this problem. I am pretty new to working with Nvidia. I am trying to have TensorRT available on Python3.8 for my Jetson Nano. TensorRT is currently available for Python3.6 on the Jetson Nano. I have this path setup for my dist-packages:
PYTHONPATH=$PYTHONPATH:/usr/lib/python3.6/dist-packages/tensorrt
I have tried to walk through a tutorial in order to build the bindings for 3.8, but with no luck:
I appreciate any help.
Welcome to the NVIDIA Developer forums! Your topic will be best served in the Jetson category.
Discussions relating to the Jetson DevKits and other Embedded computing devices
I will move this post over for visibility.
Cheers,
Tom
Duplicate to topic 287771 below:
Hello, I am trying to use TensorRT on Python3.8 on my Jetson Nano. I used SDK manager to get Jetpack for Jetson Nano, however that installs the bindings to Python3.6. I can use TensorRT on 3.6, but I’d like to use it on 3.8. I have been using this forum as a reference:
However, a deb file for the ’ Add PyConfig.h’ step for Python3.8 is not located at the linked website here . Instead, I use the pyconfig.h file that I have in my aarch64 install of Python3.8, which I assume is acceptable, but I …
