I am trying to port FFTW to 64 bit SUA using PGI compiler.
In the process i sometimes see error message saying “pgcc-Fatal-/opt/pgi/sua64/7.0-3/bin/pgc TERMINATED by signal 7”.
If i compile it again then it continues alright.
I want to know the reason behind it. Has it anything to do with evaluation license?
Waiting for your kind reply.
With warm regards,
KEDAR
ranlib .libs/libapi.a
creating libapi.la
(cd .libs && rm -f libapi.la && ln -s …/libapi.la libapi.la)
Making all in libbench2
source=‘aligned-main.c’ object=‘aligned-main.o’ libtool=no DEPDIR=.deps depmode=none /bin/sh …/depcomp pgcc -Masmkeyword -DHAVE_CONFIG_H -I. -I. -I… -D_ALL_SOURCE -I/usr/local/include -I/usr/local/ssl/include -D_ALL_SOURCE -c aligned-main.c
Arguments to /opt/pgi/sua64/7.0-3/bin/pgc
/opt/pgi/sua64/7.0-3/bin/pgc aligned-main.c -opt 1 -terse 1 -inform warn -x 59 4 -x 19 0x400000 -x 119 0x40E10400 -x 59 4 -x 70 0x8000 -x 122 1 -x 122 0x40 -x 123 0x1000 -x 127 20 -tp k8-64 -y 80 0x4000000 -x 119 0x8000000 -astype 0 -stdinc /opt/pgi/sua64/7.0-3/include:/usr/local/include:/opt/gcc.3.3/lib/gcc-lib/i586-pc-interix3/3.3/include:/opt/gcc.3.3/lib/gcc-lib/i586-pc-interix3/3.3/include:/usr/include -def lp64 -def unix -def __unix -def unix -def __INTERIX -def inline= -def x86_64 -def _M_AMD64 -def __NO_MATH_INLINES -def amd64 -def extension= -def SSE -def MMX -def SSE2 -predicate ‘#machine(x86_64) #lint(off) #system(unix) #system(posix) #cpu(x86_64)’ -idir . -idir . -idir … -idir /usr/local/include -idir /usr/local/ssl/include -def HAVE_CONFIG_H -def _ALL_SOURCE -def _ALL_SOURCE -cmdline ‘+pgcc aligned-main.c -Masmkeyword -DHAVE_CONFIG_H -I. -I. -I… -D_ALL_SOURCE -I/usr/local/include -I/usr/local/ssl/include -D_ALL_SOURCE -c’ -x 123 4 -x 123 0x80000000 -alwaysinline /opt/pgi/sua64/7.0-3/lib/libintrinsics.il 4 -x 127 1 -asm /tmp/pgcccjYgku_Iq-D.s
*** Error code 127
Stop.
*** Error code 1
Stop.
*** Error code 1
Stop.
