I am trying to initialize Tesla K80 on my system. I tried many combinations on hardware and o/s but no luck. Most of the topics about this problem only mentions enabling “Above 4G Decode” will be a solution to the Code 12 ( This device cannot find enough free that it can use ). Enabled this setting in BIOS and still facing with the same problem. Is there a any solution to this problem?
My Setup:
Gigabyte Z490 Gaming X / MSI Z77a-G43 / MSI B450m A Pro Max
Intel i7 10700K / Intel i5 2500K / AMD Ryzen 5 3600
32 GB DDR4 2133MHz / 16 GB DDR3 1600Mhz / 32 GB DDR4 3000MHz
SATA SSD 256 GB
Nvidia Tesla K80
BIOS Settings:
Above 4G Decode: Enabled (Disabled tested)
Resizable Bar: Auto (Disabled tested)
CSR: Disabled (Enabled & PCI set to Legacy or UEFI tested)
PCI Gen:3.0X (1X ,2X tested)
PS: When i reinstall the driver, I can use single K80 (It can pass Cuda Tests). When i reboot, Both K80 become problematic again.
