Tesla V100 DataCenter Driver 4XX testing on Windows 10 and Windows Server 2022 are work and the Nvidia-SMI show GPU card valid TCC. Loading some frame work and engines are work but limited on cuda 11.x.
Fresh installation window server 2022 install 55X driver with cuda 12.x , after installed and no reboot, system show GPU is valid, once reboot get code 10 error.
Try disable VT, SR-IOV, CMS, keep 4k coding and resize bar , all combination are not work.
Hardcode registry all no luck.
any one can give suggestion, thanks
Hello @kaji_trade and welcome to the NVIDIA developer forums.
Right now the recommended certified driver version for V100 on Windows Server 2022 is 582.53.
I would suggest a fresh install and checking again.
@MarkusHoHo thanks info but can not fix the issue. Once reboot will malfunction. Only 47X driver can work but not meet cuda 12.x. I run on home lab, use normal PC for testing
capture show when installation completed.
after reboot
I don’t understand what the problem is. The nvidia-smi output is completely normal.
The Device Manager also does not show details why there is a warning sign on it. That could have numerous reasons.
And wit “Fresh Install” I meant a fresh Windows Installation without installing GPU drivers and then installing the certified NVIDIA driver.
